Sand blasting alloy?
theo2468
Post by theo2468 »
want to sand blast some alloys I got, but heard if you use to strong sand it will leave dimples in the alloys.
so was wandering if anyone knew the best sand or glass for sandblasting alloy?
C25 ECV-1985-Mk2 340GL-Kessy
A889 VUY-1983-Mk2 360GLS-RUF
Best appreciated when open.
L14MNP
Re: Sand blasting alloy?
Post by L14MNP »
Is it just for removing paint? If so then Nitromorse is your friend.
STREETO WITHDRAWL
INTO BURNOUTSsince1982
L14MNP wrote:Is it just for removing paint? If so then Nitromorse is your friend.
Add a wire brush and sweat for uber-win.
theo2468
Post by theo2468 »
going to use some nitromors first, but the wheels are heavily corroded so sand blaster to get all that off.
and ive never used the sand blaster before so its abit of fun aswell.
theo2468
Post by theo2468 »
how much nitromors will i need will a litre be enough do you recon?
L14MNP
Post by L14MNP »
Aye, 1 litre tin should be fine. Or whatever size it is for £7/8.
What's the deal then, your dad got a blasting cabinet or do you mean a spot blasting gun? I have a spot blast gun and it's crap TBH.
STREETO WITHDRAWL
Evoman
Post by Evoman »
thought about getting them shot blasted and powder coated?
theo2468
Post by theo2468 »
L14MNP wrote:What's the deal then, your dad got a blasting cabinet or do you mean a spot blasting gun? I have a spot blast gun and it's crap TBH.
I've got a blasting cabinet and a new gun all on the compressor ready to go just need to get some sand/glass
Post by Hell Driver »
I've had alloys sandblasted in the past. I was told it would leave the dimples, but I didn't mind and I certainly wasn't going to sand them all! Quite liked the effect when I saw it and it becomes a softer effect with a few layers of paint. Also makes existing scrapes/dents or later scratches/imperfections less noticeable. It also leaves a mark on steels, but this soon goes with a few layers of paint. It does give a nice key for repainting too! Nice alloys those!
343 DL (W 80) :-)
R.I.P. 77 343 DL vario :-(
Probably depends on the pressure used, just back it off a bit for softer metal. I would use about 100psi for steel and it leaves a matt rough surface perfect for painting. Say 80psi for Al alloy.
