b230 conversion parts for 360
hi there im going to be doing a 2.3t (out of 940 etc) conversion on my 360 soon, not got anything yet so im just looking for parts in advance, ideally im gonna buy a full 940 and take the lump out knowing its running and lableing the wireing etc, but if anyones got the engine and loom let me know?
im after a solid flywheel (you know what i want) maybe clutch to go with it,
maybe a spare 940 engine loom,
tbh my minds gone blank atm so i will update this when i remember because i know there's more i need but that will do for now
Re: b230 conversion parts for 360
Might be better asking on TB, not too many 940s come through these parts. Or maybe even Retro Rides, I see a few b230s in the for sale section.
are there many uk members on tb? alot ive only been on quick but alot seemed to be out of the uk, i will have a look anyways and i didnt think about asking on retro rides, cheers mate
your probably better off buying a whole 940turbo and stripping it.
im currently building a 360 turbo and i have stripped nearly everything lol you dont wanna get half way and then not have something you need.
Adam.
Adam.
thats what i plan on doing mate, but from what i can gather you cant use the 940 or 360 flywheel or clutch, im gonna strip everything i can use and try and sell a few bits and then scrap the bugger lol,
what engine you useing in your build? let me know how you get on
engine is in at the moment just got mainly the wires to play with...
i bought a "H" reg 940 2.3 turbo.
old ones don't have a dual mass flywheel, so you can use the 940 flywheel still
keep the 940 clutch just use the 360 release bearing and disk.
use the 360 oil pump and sump.
the 360 alternator, water pump and pully. use the 360 mounting brackets.
the actuator for the turbo there are some clearance issues with the engine mount on the o/side.
you have to make a custom downpipe.
the 940 intercooler fits but with a few mod's.
And i can't remember the rest but i'll keep you up to date and hopefully get the pic's up to start a thread for you!
good luck.
Adam.
good luck.
Adam.
Check my thread for info mate. I think I covered what was needed when I done mine last summer.
STREETO WITHDRAWL
INTO BURNOUTSsince1982
what sorta spec is urs...e.g bhp,top speed, 0-60,0-100.
and what did u do with the actuator ??
Adam.
Adam.
ahh i didnt know that about the flywheel adam, and yea get a build thread up
l14mnp, ive had a read through yours, helped alot mate, i couldnt find out what you got the flywheel off? hows yours running? you sorted the little problems out? was a good read
just put a link up to my facebook page for some pic's the treads called Jet.
- filthyjohn
The flywheel needs the LH-Jetronic 2.4 trigger pattern, I imagine any 940 without the big dual mass flywheel (Turbobricks will clear up the differences probably) will do fine, as well as some later 740s and 240s. The earliest 740s and 240s won't be compatible as they ran Motronic or K-jet IIRC.
13431 just had a lool and its all looking good, will look forward to reading a build thread,
and cheers for the info john it will help me out,
anyone whos done the conversion could you tell me what suspension setup your useing in this thread http://www.volvo300mania.com/forum-uk/v ... =6&t=12148
Think I've got a spare oil pump and sump somewhere if needed, drop me a PM if you need either
Cheers steve, I will let you know if I need either
