I did read that winter will not be easy one:
http://www.reuters.com/article/2011/06/ ... BW20110613
http://www.exactaweather.com/UK_Long_Ra ... ecast.html
So maybe it would be good to do little preparing, just in case, some care for rubber door seals and locks would help to get in and out of car, coolant antifreeze checkup and checking battery (very old will not work on cold, also good to check water level in battery if it just has those caps to open) + fuse box connections, that should help.
Thermostat needs also changing at the times, it is not lasting forever and will cause motor not to get enough warm quickly, causing excessive petrol usage.
Don't forget wiper fluid, freezing water will break the pump and sometimes even the tank, so better have some stuff in there that does not freeze.
Choke adjustment is also much easier to do at warm summer afternoon than sub zero temperatures or when it is pissing slush and water down.
Winter is not a challenge when one is prepared to it
