Temporary b14 mods
TurboTomSportive
Temporary b14 mods
Hi guys, as you may have seen from my other thread I am going to be dropping a Renault 5 turbo engine in my Volvo after the winter. The only thing is I want more power from the b14 until it gets changed. I'm going to sort out the exhaust and probably get a k&n bolt on filter. Are there any other suggestions for a wee bit more power?
Can I get a cam? Or better plugs? Leads? Carb jets etc?
I read a thread about twin carbs, is this something worth looking into?
Thanks in advance, Tom
Edit* - also will a 1.7 5 speed bellhousing, gearbox and diff fit my Volvo?
1989 (G) Volvo 340 1.4 4-speed 5 door. More Doors - More whores
Re: Temporary b14 mods
I recently put a five speed box into my mk1 345. All the bolt are in the same place
so it is a strait swap. You wonn't have to do anything with the bell housing.
Prop shaft is also the same.
Chers Mark.
Chers Mark.
TurboTomSportive
Awesome, cheers mate, I'll go buy the box Saturday then
TurboTomSportive
Does anybody know where I can purchase a k&n (or similar) bolt on to carb filter. Also what exhaust is best suited to a 1.4? Straight through? Single box? Looking to get a filter, sort the exhaust then maybe some plugs and leads and that will do engine mod wise until I get the b14t in I think
Turnbullj hadTurboTomSportive wrote:Does anybody know where I can purchase a k&n (or similar) bolt on to carb filter. Also what exhaust is best suited to a 1.4? Straight through? Single box? Looking to get a filter, sort the exhaust then maybe some plugs and leads and that will do engine mod wise until I get the b14t in I think
THIS
On his B14. Sure you can get them cheaper, but its deffo the correct part no.
seen here.
http://www.volvo300mania.com/forum-uk/v ... php?t=7663
TurboTomSportive
Perfect cheers mate, I'll just buy one of them then I think, give it a week an I'll order that and plugs and probably leads too, then do oil and filter and mod exhaust all at the same time
there is an alternative to the k&n bolt on..... k&n do a direct replacement thats a streight swap for the round paper filter that goes in the air box...... the k&n part number is e-2820 i have one in my 340 and cant fault it..... i think you can get them on ebay a bit cheaper than the bolt on ones too
TurboTomSportive
Cheers for the heads up spike.
They seem about £30 whereas the bolt-on is a little more pricey. Anyone know which is best/better???....
as for which is best performance wise i dont know......
i went with the direct replacement one as using the bolt on one would do away with the hot-air pickup and i was told by someone on here that the bolt on ones can cause starting/running rough problems in cold weather....... dont know if theres any truth to this ... i just played it on the side of caution
TurboTomSportive
ah yes i can see why people may suggest that idea now. Hadn't thought about hot air inlet. I had a subaru mv pickup 1.8 with a K&N on once and that did play up a little in the cold conditions, Also it used to run rough (i was told due to heat build up)...May just stick to a replacement element and crack on with plugs, leads etc
Cheers Spike
Cheers Spike
if you find out about anything else that can be modded on the b14 let me know..... planning something simlar myself
TurboTomSportive
ok mate i'll keep you up to date, As i say my first mods will be
-K&N Filter
-Iridium spark plugs
-Magnecore leads
-Free flowing exhaust
-Good service
then depending how long it takes for me to sort the B14T out, i may look into making a custom manifold at work and looking at twin carbs
or the likes. possibly some mild headwork/cam or similar.
I know it would be quicker/easier/cheaper to drop in a bigger engine but i like having unusla project
-K&N Filter
-Magnecore leads
-Good service
TurboTomSportive wrote:ok mate i'll keep you up to date, As i say my first mods will be
-K&N Filter
-Magnecore leads
-Good service
^all good ideas
^Bike carbs? Think people have ran ZXR 600 carbs on 1.4 TU engines. Never seen them on a B14. So I dare you.
im currently researching a way to make a b14 turbo (or possibly a renault 5 gt swap) work with a cvt ...... so far all im hearing is that it cant be done as the cvt cant handle the power...... but my feeling is that where theres a will (and a credit card) theres always a way
custom prop and low boost.spike4073 wrote:im currently researching a way to make a b14 turbo (or possibly a renault 5 gt swap) work with a cvt ...... so far all im hearing is that it cant be done as the cvt cant handle the power...... but my feeling is that where theres a will (and a credit card) theres always a way
i dont see the problem man.
More expensive that a manual. But would be epic.
