volvo redtop into a 360?
sammysideways
Post by sammysideways »
ok maybe a change of plan, i need info on this swap.
Whats cars can i find the engines? whats the best version to go for and what modifications are needed? what sort of power figures from stock?
L14MNP
Re: volvo redtop into a 360?
Post by L14MNP »
You on about a red block? I'm confused, especially as you mention it's for a 360.
STREETO WITHDRAWL
INTO BURNOUTSsince1982
Redblock link
Im often wrong, but I though all B series angines were "redblock"s???????!
Just need tuned for RRRAAA!!!!!! POWWWWWAZ!!!11!!!!
Cam n carbz ftw.
*Edit - oh, and a big Turbo helps.... 8)
sammysideways
Sorry i should of been more exact. I meant the b230et engine/2.3 turbo lump
sammysideways wrote:Sorry i should of been more exact. I meant the b230et engine/2.3 turbo lump
Sorry troop.
740s and 940s.
940s go for scrap money. So maybe do what almost everyone else has done and buy one, pull the lump, weigh the rest.
Free engine swap?
Go for it man. 300s need more turbo!!!!!!!111!!!
L14MNP
Post by L14MNP »
[Zed head] Joiiiiinnnn uuuusssss [/Zed head] 8)
Have a look at mine, 123453456789876567334565433111 and wiganer31's threads for an idea mate.
It's not too involved. I'd get looking for a flywheel now though! :lol:
STREETO WITHDRAWL
sammysideways
What flywheel do i need?
Also do i use the 360 box/bellhousing or donor cars?
Its either i go 2.3 turbo lump or sr20det it
But...... Do it.
Do it, do it.
L14MNP
Post by L14MNP »
sammysideways wrote:What flywheel do i need?
I'm glad SR20's are finally getting the good press they warrant. I love how cheap the iron block Volvo stuff is though. Grenade it, and it doesn't matter (if stock), just another £100 or so and you're running again. :lol:
Like I say man, check the threads, this has been asked loads. Also search for a thread by my old user OapEM where I was asking the same questions.
You need a 'dog dish' LH 2.4 fly. 360 drive train, sell the M90 box from the donor (if you get one).
STREETO WITHDRAWL
And some wire cutting scissors. And patience.
sammysideways
Also what sort of power do they make in standard format?
Enough power! 165hp/4800 for a standard B230FT, 200+ with a little extra boost that will max out the 360 drive. No need for extra tuning or bigger turbos, although the waste gate is a bit restrictive on extra boost, the inlet has no problem keeping up the pressure.
Try the Engine tuning section, but don't try searching for 'turbo' the site software won't allow it and complains its too much.
The biggest problem is the flywheel+clutch, but you can get it to work with just the 360 clutch plate, which is usually a bit small for the 200/700 flywheels. If you get a 94-on 940 you will have to ditch the dual-mass flywheel which won't fit in the 360 bell housing.
I would buy an early (up to 1994) 940 manual as the donor, that way you get the right flywheel. Saloons will be cheaper. You miss a few goodies from the later engines (like oil squirters), but it really doesn't matter.
Read Liam's, Wiganeer and Adam's threads, and come back with any specific questions.
Keep on hearing about these scrap value 940s, but I never seem to find them. Most are 500+
Speedy88 wrote:Keep on hearing about these scrap value 940s, but I never seem to find them. Most are 500+
think Liams was 150?
they are out there.
