1.7 engine hesitation when accelerating
charlieog1243
Post by charlieog1243 »
hi i have 2 volvo 340 1.7 and both of them when u stamp your foot down they judder and act like there going to stall then they go i have put carb cleaner into them still no change do i need to get the carbs cleaned/re jetted?
Re: 1.7 engine hesitation when accelerating
Sounds like it's flooding with fuel. Does it also barf some black smoke out the exhaust?
charlieog1243
Speedy88 wrote:Sounds like it's flooding with fuel. Does it also barf some black smoke out the exhaust?
not that i no of have not seen any it feel like when u slip of the clutch when pulling off kangarooing abit then its fine but it does stink of fuel so mayb your correct
more likely a weak spark, possibly caused by oil in the disty.
charlieog1243
Ride_on wrote:more likely a weak spark, possibly caused by oil in the disty.
plan of action is change the sparks and clean the dizzy out then i take it will update if it fixes it thanks
charlieog1243
cleaned the dizzy have not changed the plugs yet waiting for them to arrive would a dirty dizzy and shit plugs make it smell it sometimes stinks of fuel when i put my foot down?
possibly, the theory is that the fuel drowns the spark, so you will get a load of unburnt fuel. Usually the symptom is stalling when trying to take off and apply power, or just generally applying power.
Post by volvodspec »
check the float in the carb, it's probably leaking and filling itself with fuel
