Power Steering on 340 DL - 1.4
I wish to confirm that a 360 Power Steering Rack will fit in place of the manual steering rack, in terms of bolt positions and any other factors such as lower steering column connection.
Regards
D24Tdavew
Regards
D24Tdavew
You also need space and correct pulleys for the hydraulic pump.
Do you really need power steering ? Try greasing the steering rack and tyres at 30 psi . The 340 steering should be quite light once you move . Turning the wheels when stationary is not good for tyres or steering parts.
regards, Steve
regards, Steve
1989 340DL,1397
1979 CapriGL ,1593
1979 CapriGL ,1593
Thanks all.
Do I take it that a 360 Power steering rack WILL fit for definite ?
The reason for the question is that I obtained a rack supposedly from a 360 via a Volvo dismantler last September.
I have only just got time to fit it, and the mounting holes are miles off.
It was this that prompted the question.
Personally I think the steering is heavy, and I agree that when you are in motion it is manageable , but sooner or later you have to rotate the wheel at low speeds or when stopped such as when reversing into a parking spot which is when the problem starts. Its my daughters car anyway and wieighlifting is not her sport.
The pump I have is an easy fit, so that is not the problem.
Regards
Dave
D24Tdavew
Regards
Dave
D24Tdavew
...just think of how much more stress tyres are under driving, especially at speed and on some surfaces and things...MJ wrote:How can turning wheels when stationary not rub tread off
If your tyres couldnt survive simply turning your wheels when stationary without being damaged, they wouldnt be able to handle driving stress!
I remember when the Formula 1 was on a week or two ago, and in the few minutes I watched they were talking about tyre wear. They said that the tyres don't wear out when cornering, but they do when the breaks lock.
When you turn the wheels at stationary they are rubbing a lot.
Just imagine that you have a rubber (pencil errasor thing
) thats shaped like a polo with a hole in the middle. If you put a pencil through the middle and roll it along the table in a circle, I dobt that any of the rubber would be damaged. Now if you hold the rubber between you finders and turn it on the desk, like car wheels when the car is still, I expect theat some of the rubber will come off
your right. tyres do wear naturally just by accellerating, breaking and cornering (hense why f1 tyres go even if they dont lock up), but they wear slowly. drysteering puts a lot of strain on the steering components and wears the tyres. dont do it!
Whats the easiest way to put the pump on the 1.4? Is it a case of getting a different pump, or can you put that one on. And how do you hook another belt up to the crank?
Have you ever fitted the extra pully on a 1.4 Daffodil? I'm sure if I had a proper look all would become clear, but is it as simple as going to th escrappy, finding another 1.4, nicking the pulley, and using some longer bolts to bolt both pulleys on? (assuming the pulleys do bolt on that is).
