engine problems lol
charlieog1243
engine problems lol
Post by charlieog1243 »
1. car cuts out every now and then like when im driving if i coast down a hill etc it will cut out
2. a silly question but were is the hole to out the gearbox oil in lol i no on the gearbox but where abouts top,right side,left???
jon-ovlov
Re: engine problems lol
Post by jon-ovlov »
Check your idle screw on the carb. The connection could be disconnected, or dodgy.
The gearbox drain plug is on the bottom. It's a 20mm or 22mm nut, something like that from memory.
Give neighbours thumbs up
Rev engine to 7K
Exit street sideways
Win at life.
charlieog1243
jon-ovlov wrote:Check your idle screw on the carb. The connection could be disconnected, or dodgy.
how do u fill the bastard up if its at the bottom? lol
Nimminz
Post by Nimminz »
there's another on the side (N/S IIRC) of the box :)
jon-ovlov
Post by jon-ovlov »
Yup! or try to defy gravity. Usually, things end up failing when that happens :lol:
Rev engine to 7K
Win at life.
Can be really hard to get the side bolt off, you might need to drop the gearbox to get a hex socket on it. That is its assuming 360, if its a 340 should be less of an access problem.
charlieog1243
nice one will battle with it tommorow lol ye its a 340
