how remove readiator?
frazeb
Post by frazeb »
iv disconnected all the pipes but i cant see any bolts holding it on. what do i need to do?
T.J.
Re: how remove readiator?
Post by T.J. »
There's bolts on the top and bottom of the radiator
frazeb
Post by frazeb »
theres no bolts its on liker rubber sliders iv undone them all now but it wont come out through the engine bay
T.J.
Post by T.J. »
you're supposed to take the front bumper off and remove it through there
It would be helpful to start with the model and year.
frazeb
Post by frazeb »
its a 88 volvo 340 thats all i know really i tried getin the bumper off but i couldnt get it past the wipers for the headlights
jon-ovlov
Post by jon-ovlov »
Wipers have a little nut on them, under a cover. flip cover, remove nut, pull headlight wiper off. This leaves a stub. Then remove bumper. Solved. :D
Give neighbours thumbs up
Rev engine to 7K
Exit street sideways
Win at life.
Post by MCHUDD »
Hi frazeb.
Once you get the bumper of,shine a light at the tpo and back of the radiator.
You will see 4 10mm bolt. These hold the top of the rad to the car.
At the bottom you will see 2 10mm bolts. These hold the bottom of the rad to the car.
When these are all removed,the rad will lift out.
Fuse
Post by Fuse »
It's not even necessary to remove the front bumper. The radiator comes out through the opening when you remove the front grille. But it's easier when the bumper is out of the way though.
frazeb
Post by frazeb »
thanks for the help once i got the wipers of it went smooth from there and it was out in like 10mins
