Torque settings - Torque tube to gearbox clamp?
Hi, haynes isn't very clear but does anyone know the torque settings for the 2 allen-key bolts on the torque tube clamp? I found one setting which said 72Nm. Seems a little high :shock:
Re: Torque settings - Torque tube to gearbox clamp?
Post by volvodspec »
they're std M10 thread and 10.9 tensile so yes 72Nm is correct
Ok that's good then :D Thought I'd over-tightened them. Thanks mr D-spec.
Wooahh! Haynes says 34Nm 'propeller shaft clamp bolts B19 +B200 34Nm'
You have over tightened them, I would renew the bolts now.
huh? i thought you ment the 4 allen bolts that bolt the torquetube to the gearbox
the clamp that joins the gearbox input shaft to the prise axle is indeed 2x 34/35Nm
Oh whoops, yeah luckily I have some spare.
