URGENT!!!!!wanted: Front X-mem for 360 and GLT Diff
Nimminz
Post by Nimminz »
EDIT:
Am after a front crossmember. Its the tubular one that has the central ARB mounts. For 360 GLT '88. Don't think there's much difference with 360 ones. Kinda bent mine
Also a 3.64:1 360 GLT Diff, casing and pinion - the lot. would even take it stuck to a 5-speed box if the price was right
If anyone's got one and could brink it at the weekend to the meet, would be mint!
Got two diffs with a 3.64:1 ratio and no pinion shafts to match - it's not urgent at the mo, but wouldn't mind them, espeially if anyone has one they can part with who's coming to yorkshre in september for the meet. Have diff cases so just the shaft is preffered
Cheers,
Matt
sven360
Re: wanted: 3.64:1 Pinion Shaft
Post by sven360 »
IMHO it's not good practice to mis match C/wheel and pinion.
Buy a complete unit would be my advice.
Write it in your heart.
The code of the West.
Nimminz
Post by Nimminz »
even with the same ratio? ah well, i have 2 useless but working diffs :( will buy a complete one when i need it then
sven360
Post by sven360 »
I'd be happily proven wrong,just not summit I'd do myself.
Complete unit should be cheap enough.try FJ.
Nimminz
Re: wanted: Front X-mem for 360 and GLT Diff
Post by Nimminz »
BUMP
Edited first post
Nimminz
Re: URGENT!!!!!wanted: Front X-mem for 360 and GLT Diff
Post by Nimminz »
Could REALLY do with this x-member at the weekend!!
Nimminz
Post by Nimminz »
BUMP
Ned this x-member curently driving with no front ARB
L14MNP
Post by L14MNP »
Did you get one mate? I have the one from my mk2, but I think the ARB mounts differently?
STREETO WITHDRAWL
INTO BURNOUTSsince1982
Post by 340GLT »
a 340 one will fit if you cut the engine mounts off.
Nimminz
Post by Nimminz »
I currently have a 340 one on with the engine mounts cut off, Only problem is the ARB mounts are rotted through :/ Liam's sorting me one though :D
L14MNP
Post by L14MNP »
Nimminz wrote: Liam's sorting me one though :D
Forgot to text you Matt. Picked it up from the garage this afternoon for you mate. 8)
STREETO WITHDRAWL
Nimminz
Post by Nimminz »
Spot on mate, I'm away this weekend but I'll give you a text when I'm back and see when i can come retrieve it :)
