No more megasquirt in 360 :(
Yes, had to remove it because of MOT.
My car is made 1988 and around mid 1987 is point where rules changes so that I would need catalytic converter to pass mot, then they mark is less polluting vehicle and no mods are allowed to engine anymore.
So back to carb sh*t. Fuel injection is much cleaner but they force me to use carb, great law...
Now I'm planning to get all engine mods at once and then also cat, so I could have even some power.
However I have started to think about another way, older car and put megasquirt to it.
Too bad that I have really put some money into my current car and lot of work, there is not very many things that would require work for it to be level that I like (near perfect).
So here I have now something to think about.
- petefarrell360
I guess I could take roof off and no changes to insurancepetefarrell360 wrote:Those laws sound ridiculous! A few months difference, and yet the rules change so much. Well, hope you figure something out! What's your insurance like with modifications, as here they are pretty paranoid about any changes, even cosmetic ?
It could be worse, as you see in worse case this limit is only one day, it is not based car model or anything like that, they just did the easy thing and decided that this is the date and that separates even two identical cars. Well, our goverment has never proven to be too intelligent, imo...
We have kinda similar, anything after '92 MUST have a cat, but I don't know how tight the MOT is with it, as a lot of people take them out, not that the 1.1 corsa will benefit much!
I think that we have that too, cars after 92 are almost impossible to mod, if one likes to add turbocharger over, 1000 euros needed for emission tests.Chris_C wrote:We have kinda similar, anything after '92 MUST have a cat, but I don't know how tight the MOT is with it, as a lot of people take them out, not that the 1.1 corsa will benefit much!
I think that I will get older car while they still exists
- foggyjames
Couldn't you tune MS to not kill the cat? Or is this simply modification related, not emissions? If you could modify it for more power, but still improve the emissions (perfectly possible), and they still have a problem...that's crazy!
I don't have a cat. If I put cat in then I could not anymore alter engine, so no turbocharging etc.foggyjames wrote:Couldn't you tune MS to not kill the cat? Or is this simply modification related, not emissions? If you could modify it for more power, but still improve the emissions (perfectly possible), and they still have a problem...that's crazy!
But if I put turbo and stuff in and then throw a cat in too, no problem.
Oh yes, it is crazy, stupid, idiotism, but car hobby is almost a crime here I see
They have no problem with broken cisac that makes lot of pollution, but they do have problem with fuel injection conversion that is not polluting even near as much as is original.
Not allowed to use brains, 'book says this and we do this, we always have, we don't think' is their song I think.
Driving with cisac is quite a pain, with small throttle car is like skippy, jumping a lot, with more throttle less like skippy, but still engine is not running smooth, only at full throttle it seems to work barely.
Need to take renix out and clean it first, maybe I also buy B19E ignition stuff so I can test if it is indeed ignition related.
I had very little same like problem with injection stiff installed, but it was not really a problem, adjusting problematic rpm area to richer mixture solved it, so I think it is ignition related problem.
- foggyjames
Solex CISAC 34/34
CISAC is the model, and 34/34 are the throttle butterfly sizes.
Similarly, my carbs are ADDHE 40s
