Are 3 door and 5 door front seat subframes the same?
Desperately need a new subframe for the drivers seat to get through an MOT. If 3 and 5 door frames are the same (mounting to the floor, fore and aft adjustment etc] then i can broaden my search. Thanks. Rich
Re: Are 3 door and 5 door front seat subframes the same?
I would say they are the same. As the 3 and 5 door shells are the same, all
the mounting holes for the seat belts and seats should be the same.
awesome, thanks alot mate, that is what i was thinking but wanted to double check. cheers.
Seat belts definitely arn't, the bottom fixing is a bolt eyelet on a 5 door and a sliding loopy thing on 3 doors. No idea about subframes I'm afraid, the seats do differ but I'm not sure where the mad dutch pivoting happens.
- volvodspec
the slider frame (front to back adjustment with the lever under the seat) are the same, everything else is different.
Thanks for the replys, ended up modifying a set of ford runners instead, MOT was getting close! cheers.
