No-idea what's happening to my engine-
CBA
Post by CBA »
Here we go:
1.7 @200k miles ish.
Cold morning: Full choke, turn key - fires almost instantly in that snow-covered volvo way.
Car idles a little unsteady but not concerning.
Once engine is warm and I'm off choke this happens:
Past 50% throttle over 3000 revs the engine gives a nasty continuous grating noise, I'm not sure if its preignition or detonation or a loose component,when the grating gets noisier it does seem to sap power e.g. more accelerator(past halfway) = less power.
To me it sounds like a really OOB thing on a shaft with loose bearings ragging itself to bits?? like a worn viscous coupling, doesent "roar" though, it's grating. sm93
Re: No-idea what's happening to my engine-
Secondary carb jet blocked? I suspect your issue could be only there when the second flap opens?
Have you made sure that no of teh pipes etc have fallen apart?
CBA
Post by CBA »
pipage is all good, no vac leaks no fuel leaks. I'm tackling it soon just thought it might strike a chord with someone.. will whip out the jet :)
More accelerator = less power
And its not a weak spark ie missing badly?
CBA
Post by CBA »
hmmm.. my battery is goosed e.g. needs a push first thing. got a few ideas now, cheers.
