I read that:
1. Turn idle up nice and high (1500-2000rpm~)
2. adjust mixture to get highest possible rpm.
3. adjust idle back down as desired
4. if idle wont go low enough- turn mixture screw inwards as little as possible
But firs of all I can't get to 1500-2000rpm by unscrewing idle screw. What could couse that? Also is it should be like idle screw don't pulls out? I unscrew idle screw all the way and mixture screw pulled out and it shows something just above 1000rpm. Wtf?
setting mixture
Re: setting mixture
I found some cracked hoses:
Also this hose has open nipple. What shoud be connected to that nipple because there is no loose hose:
This hose comes from breather on the block if I'm correct:
Re: setting mixture
My suggestion.....
Change all the hoses first before attempting any further adjustments. It sounds as if an air leakage problem is causing your first problem.
John
John
Re: setting mixture
It is almost impossible to get parts for 360, but I will try to fix my hoses and see what is happening. And what abou that nipple? Where it should be coneccted to?
Re: setting mixture
The hard plastic peice goes into the breather/flame trap. The small bore pipe goes to the inlet manifold.
Make sure the flap trap is clean.
Re: setting mixture
Where I could find that flap trap? Is it that plastic box on the block? And what exactly there should be clean because that plastic box itself is covered with oil/dust.
Re: setting mixture
The flame trap stops any backfire for getting to teh engine oil.
Inside the bit on the engine block there will be eitehr a metal wire filter or a plastic one with lots of round holes. They block up and stop the engine from breathing. Give it all a good clean up while it is apart
Re: setting mixture
Thank you a lot guys. I would try all things you mentioned. It seems that I need to create my cars thread.
