availability of seals/bearings
madseb
Post by madseb »
Hello all,
I was hoping that someone could shed some light on this for me.
currently reconditioning a diff assembly, and was wondering if the seals/shims, and bearings are still available from Volvo, or a possible parts supplier.
I am in need pretty urgently, as id like to get the unit built and installed over the next month, for a meet deadline.
I've scoured the green book, and cant seem to find any part numbers either.
any help is greatly appreciated.
thanks
madseb
Re: availability of seals/bearings
I've identified the output bearing and seals in the LSD thread, if thats any help.
viewtopic.php?f=53&t=11312&start=180
madseb
Post by madseb »
Thanks for the help ride on. I have indeed read your posts many times.
And Thankyou for highlighting the aftermarket options.
I'm in desperate need to identify a supplier for the output shims and crush collar for the input shaft. And also the associated bearing and seal.
Big thanks for your help. This has already reduced the workload.
Madseb
I didn't do those on mine, but I might regret later. Do post whatever specs/part numbers you identify.
