Help find a part
Kristupas
Help find a part
Post by Kristupas »
Hello ,
I need to find a new or used part on which the rear wheel is mounted. Don't know how it's called. It should look something like this
http://s214.photobucket.com/user/turbea ... 7.jpg.html
It's from a 360. Haven't removed it yet. Maybe someone knows the part's number? If I can't find a new one maybe I can find a used one ? What other volvos used the same part?
Re: Help find a part
Post by bogbasic »
Half-shaft?
Joris
Post by Joris »
Wheel Hub?
Wheel axle?
No. 9
360rearaxle by macplaxton, on Flickr
360 up to chassis number 120999 part number 3280432
340 / 360 from chassis number 121000 (MY1986) Part number: 3245853
If you need wheel flange, hub or or the bearing, you will need a new bearing. Taking out the wheel flange will destroy the bearing.
Its a bit tricky but do-able.
viewtopic.php?f=54&t=10548
Kristupas
Post by Kristupas »
I still don't get how to take the wheel hub of. This is how it looks without the drum.
As you can see it needs new studs. Do I need to remove the axle somehow to get the hub off?
Kristupas wrote:I still don't get how to take the wheel hub of. This is how it looks without the drum.
Disconnect the outer driveshaft CV joint first. Then undo big nut on inside.
See: viewtopic.php?f=36&t=7264 "Steering PDF" page 45 for more details.
Then you need a good puller. Also as above you will need a new bearing.
And what is that twin turbo 6 pot going into?
