Renix crank shaft sensor
Could someone take a pic of stock Renix crank shaft sensor on it's place. I'm just wondering if it has been moved in GLT because in GL there is just a small hole on the bellhousing where the CPS is located and in GLT there's this gap which is few centimeters wide and it seems to be differently mounted too. I just wanna find out if it has been moved to change timing or are those just standard differencies between different models.
Thanks. Also in GL the vacuum unit of the Renix has never been connected and in GLT it is. I'm just trying to find out if there's some changes made to ignition.
