Rear Shocks
Volvo 360 GL B200K
Rear Shocks
Post by Volvo 360 GL B200K »
About 6 months ago i found a 360 GLE at the scrapyard, with vertually brand new rear gas struts, so out with the spanners, and off they came! I then fitted them on my 360 GL, i.e. removed the fitted oil shocks! When the gas shocks were fitted the back and had raised about an inch higher between the rear wheel and wheel arch! I then took the car for a spin (not literally but nearly) i drove it up the road to the round about, where i gave it the usual stick around it, then found to my surprise when i nearly hit a lamp post that the rear shocks had stiffened the rear end so much that the oversteer turned to understeer! Frightening!!!
Anyhow, despite taking a while to get used to it, it decreases the body roll round corners and generally makes it a much more pleasent ride!
Cheers :D
I think GLTs had gas shocks from the factory...(maybe?!)...
If you have the £££ you wanna get a set of Bilstiens custom ported to match the ones for a 343 R-Sport ;)
Duvel78
Website Admin
Post by Duvel78 »
foggyjames wrote:I think GLTs had gas shocks from the factory...(maybe?!)...
True :360: GLT
V3M for life!
5lab
Post by 5lab »
i thought glts only had different front shocks?
i think the stance would be a bit better with a higher rear end. very tempting..
Volvo 360 GL B200K
Its a big improvement, stops your passengers thinking their on the QE II!! GLT's came with different front and rear shocks and also different rear leaf springs, however not sure in what way they are different - possibly stiffer?!
:360:'s RULE
