Fuel pump
D4V2K1
Fuel pump
Post by D4V2K1 »
Does anybody know if this would fit my 360 B200E??
http://cgi.ebay.co.uk/NEW-OLD-STOCK-VOL ... dZViewItem
Dave
1988 360 GLT (5dr) 85k - Gone but not forgotten
http://www.car-culture.co.uk
Fuse
Post by Fuse »
Nope that wont work as it is a mechanical pump meant for carb engines. You need a high flow electrical pump which goes near tank. :P That mechanical one goes in to the block and doesn't work with injection.
D4V2K1
Post by D4V2K1 »
Thanks for that. :)
I'll keep looking.
yeah, looks like a pump for a carb car. Dunno which one though, couldn't find the part number not recognised :?
I think that one is for a B14. Try taking the '-' out of the part number...but of course Vadis doesn't have all the old part numbers :(
antiekeradio
Post by antiekeradio »
looks like the old-fashioned DAF pump!!!
[edit; 95% certain it is! can be fitted on DAF 55, 66 and Volvo 66]
D4V2K1
Post by D4V2K1 »
That's another mechanical pump. You're looking for something that looks rather like an oversized can of coke.
Here is one old photo from my engine room:
Between brake servo and intake manifold you can see my fuel pump, it is attached to intake manifold, metal color cylinder shaped thing.
D4V2K1
Post by D4V2K1 »
antiekeradio
YEP, thats the one you want! 8)
D4V2K1
Post by D4V2K1 »
Thats all i needed to know, cheers!
Did anyone check the part number? I don't have VADIS to hand. Not all of the pumps that look like that are the right one for LE-Jet.
Hmmm, good call Foggy, that part number is for a 740 fuel pump. 740s run LH2.4 but does that mean that the pump isn't going to supply the correct/enough pressure or is it just a higher flow rate pump that will work fine on a 360?
Most injection 740s (up to 1990) run K-Jet, which runs a much higher fuel pressure than EFI. As long as that's an EFI pump, you should be fine, as a 'bigger' pump will simply give you the potential to fuel for more power. I have no idea what effect the pump for mechanical fuel injection might have on an EFI system.
Did it say which engine it was for Andy? B200F or B230F good, 200/230E bad. 234 good. 200/230 Turbo good.
