REMOVING STEREO - UPDATE!!!!
Sam340
Post by Sam340 »
Have put some rear speakers in the back of my 340 today...
Went to take stereo out so i could swap it over for my CD player and attatch rear wiring.
Started off by using Din Keys, which i have always used and they didnt work. :?
I then tried slipping knife blade down the sides of the stereo but to no avail.
I then moved clock / ashtray thinking that i would be able to reach the back of stereo and give it a helping push out from behind but stereo is in its own plastic surrounded unit.
Then proceded to take glovebox out to get in that way and still couldnt get to it..
Are the headunits bolted in to the car at the back?.... if so how do you get to it...??
Any suggestions please, getting fustrated :evil: ... dont want to get angry and damage any part of my dash / facia
Ali
Post by Ali »
It definately shouldn't be bolted in, I think they just are a PITA to get out really, can't get in from behind as the only small hole is to let the wiring through, think you'll just have to stick to jiggling about with the din keys, seem to remember having the same trouble with mine and now my head unit doesn't stay in, likes flying out of the dash at me under heavy acceleration in 1st :lol:
Sam340
Post by Sam340 »
Great lol,
Really went at it wiggling whilst pulling and all sorts, was trying not to break origional stereo just in case. Might have to take a more heavy handed approach tommorow!! :twisted:
Sam
d3k4y0
Post by d3k4y0 »
If you take the cover underneath the stearing column off (the little carpet stuff) you can get to the back of the stereo to give it a shove from the back (follow the centre console column up)
If the stereo is anything like the one that was in ray when you got it, you can't get any purchhase with the din keys so put them in (or make some from wire coathangers if din ones wont fit at all) then push it from behind, shouldn't need any real brute force, just some gentle persuasion
D4V2K1
Post by D4V2K1 »
Mine was bolted in from the back. Best bet is to take the glovebox out (6 screws) then you get plenty of room to see whats what.
antiekeradio
Post by antiekeradio »
yep the OEM radio's sometimes are bolted in from behind.
sure thing to check when it won't come out with the din keys :wink:
Sam340
Post by Sam340 »
Hmmm Have taken glovebox out but cant see anything apart from the plastic box that the stereo sits in....
If it was bolted in i dont see how i would be able to get to anything to undo it........
oh well will have another crack 2moro.
Sam
Post by redline »
look for a little nut (no not you James ) at the back of the plastic cowl that encases the radio , sometimes they are bolted through the cowl to support the rear end
5lab
Post by 5lab »
i used a crowbar last time :D
try getting the surround out first, rather than the stereo. i've not seen a surround that doesnt come out with a little persuasion.
Post by redline »
5lab wrote:i used a crowbar last time :D
subtle as ever
5lab wrote:try getting the surround out first, rather than the stereo. i've not seen a surround that doesnt come out with a little persuasion.
Dude... are you telling me that you've got that surround out with the HU still in and not damaged the dash? Thats how the theiving t*ssers nicked my stereo, but they left a nice screwdriver mark on it for me.
As above for help though, take the two covers off, coat hanger style keys in, and gently wiggle from back and front, and check that bolt. You're new CD player should have a rubber bung on a bolt, if the old one is bolted, it'll be in that place on the back face of the unit.
Sam340
Post by Sam340 »
AAARGGGGHHHHH.....
Really starting to wind me up now... been at it for about an hour.. wont budge...
Took the glovebox out again as suggested as well as the panel under the steering column but still couldnt get any real access to the back... could just about feel back of head unit with fingertips but thats it.
I then thought i could take the whole facia panel off and started taking out clock etc but according to haynes to remove the whole panel you have to remove two screws that are inside the stereo bit.....????
I have never had so many problems taking out a stereo before... i feel like giving up but cant bring myself to listen to tapes!!!!
Post by redline »
nuthin wrong with tapes , ive got about 300 of the bloody things
5lab
Post by 5lab »
put a thin bit of metal in one side of the facia adapter. it is held in with clips - one each side, you should be able to push the clip towards the stereo, that side will suddenly pop out; do the same on the other side and you're onto a winner
garethreece
Post by garethreece »
I got a Volvo 4 stereo in mine with the knobs for Vol/tuning and you remove the head off the 2 knobs and poke wires into a little hole behind that releases the clip. I get the instruction book out if yours is similar and my instructions are two vauge.
B980EAV '85 340 GL
SMO58Y '83 360 GLS
VK06FKP '06 Suzuki Swift 1.5 5dr
N62NTG '96 Ford Mondeo 1.8TD
And only 2 of them are on the road :(
