Half shaft Compatabilty
Post by 340GLT »
Right i have been looking at the halfshafts on a 360 and the shaft itself is larger in diameter to the 340. Does anyone know if they will bolt onto a 340 or is there a reason they wont?
Also according to vadis there is a load of varients of the actual continual velocity joint on the end which i cant understand? According to vadis they have diff part no's!!
Thanks
I've got 360 drive shafts on Vickys 340. The reason for this is that here cv joints were on the way our so I just removed them from our dead 360. I also used the 360 bolts as they have a proper 10mm head instead of the allen key used on 340's.
Post by petefarrell360 »
Ok mate, I'll try and bring all the associated bolts if the heads are different for you.
Post by 340GLT »
Cheers for that guys!!!
Oh balls, didn't check for 360 ones being different. I might have to pilfer a set Mr Farrell ;)
Ok, sure we'll have a set for ya. Add it on the shopping list!
