driveshaft grease
brad360
driveshaft grease
Post by brad360 »
I am told the rubber cover is loose on one driveshaft and whatever is underneath it could do with some grease or something.
Is this urgent?
What do I need to do? Remove the rubber thingy? clean under with anything? What sort of lubricant?
Can the rubber thing be hed down with a plastic cable tie?
360GLT
You need a new rubber boot probably. Use CV joint grease. New boots are only a couple of quid.
germ
Post by germ »
i am going to use copper ease grease :oops: as its all ive got at the moment :oops:
Volvo 340 Image 1988
A M R
Post by A M R »
lol dont use that stuff!
tbh, just dont drive it until you can get some cv grease. if left for a long time the drive shaft will start corroding and wearing heavily due to friction and heat. eventually you will have a horribly clicking sound when you turn a corner and then it could possibly fall apart and you'll be stuck in the middle of nowhere.
NO
Copper grease has metal particals and will couse the joint to wear. Get the right stuff its not expensive
germ
Post by germ »
OMG! :( errrr em i talk about splines and you? :( it says in haynes use brake grease :S
A M R
Post by A M R »
dont listen to haynes!
just go buy the right stuff. its not expensive.
A M R wrote:lol dont use that stuff!
On rwd you dont notice it as bad a fwd but running dry will cause damage. On FWD the most strain is when turning but this is not the same, even so make sure you use the right grease and do not use it untill you have reagreased.
When my rubber split I cheated and changed the shafts as I had better ones.
classicswede wrote: When my rubber split .
Mick leave it :D
germ
Post by germ »
damn i am talkin about the wrong thing i dont mean driveshaft :oops:
i mean the thing that goes into the clutch with slines also the propshaft slines
and got confused with the words today all ive done is be confused :?
sorry :( but i guess its still just as bad? although there isnt movement between the spline thingys.
A M R
Post by A M R »
is there a french word for 'spacktard' ???
germ
Post by germ »
wtf is spacktard???
A M R
Post by A M R »
cross between a spastic and a retard lol
germ
Post by germ »
i see......
....yes i am or i was before 12.00 :P
ive just been baffoled by every thing to day no idea why
maybe a gas leak :shock:
Copper grease is perfect for lubricating the splines on the prop.
