Turbo / Dump Valve / Intercooler / Anti roll Bar
1stRaven
Post by 1stRaven »
I currently have the following parts for sale.
Brand new XS Power T3/T4 turbo - £180 ono
Its not a garret but its cheap enough to run this one and replace as needed. I brought this as I thought the bearings had gone in mine - turns out the wastegate was stuck open. Doh.
Specs:
3" INLET DIAMETER
2" OUTLET
WET FLOATING BEARINGS
1/8 NPT OIL INLET
T3 FLANGE
.50 A/R COMPRESSOR
.63 A/R TURBINE
.57 TRIM
Oil cooled only
Baileys DV26 Dump Valve - £50 ono
I have had to upgraded to a larger DV36 so my old dump valve is for sale.
Front Mount Intercooler - £25 ono
18" High, 28" Wide from the ends of the hose connectors. Intercooler is about a 1"-1.5" thick with a wider metal top.
Volvo 200/700/900 Anti Roll Bars - £25 ono
A set of front and rear roll bars from a 740 turbo. 21mm front and 19m rear.
[center]
[QUOTE=foggyjames]...Ryan's car is pretty much spot-on....[/QUOTE]
[/center]
have you got a pic of the intercooler?
Do you have a set of 23mm bars for a 240?
1stRaven
Post by 1stRaven »
I dont have a pic at the moment but will get one taken tomorrow and get it posted up.
Dump valve is now sold.
[center]
[/center]
and teh 240 antirol bars?
1stRaven
Post by 1stRaven »
sry, missed that part.
No, I dont have any 240 parts.
[center]
[/center]
kaos
Post by kaos »
would be intrested in the intercooler
