Poor starting & poss. overheating on B200Fs
Posted: 25 Oct 2007 01:33 pm
Poor starting / overheating? on B200Fs
I've got 2 360 B200Fs, with slightly different engine problems.
Car 1, the '88 GLi
#Starting#
starts well in any weather, however when the outside temperatures are cold the idles drop rediculously low (~500 rpm) and I'm pretty sure I can smell petrol. Once the car warms up, everything is fine, it idles at around 8/900 rpm.
#Cooling#
No problems. Even at outside temperatures of 40°C+ or steady autobahn speeds of over 100 mph the needle barely moves much beyond the middle of the gauge.
All the air & fuel filters on this car are new(ish) as is oil & water.
Car 2, the '88 GLT
#Starting#
doesn't start as well as the GLi. It seems to take longer to "catch", and it doesn't seem to make much of a difference whether it's a cold or a warm start. Three or four times in the last 6 months it hasn't started at all in the mornings, come mid-day however, the car starts. Idle speed is quite high, around 1250 rpm.
To cut down the possibility of it being ignition, I put new spark plugs in and swapped dizzy cap, rotor, leads and the renix module over from the GLi. It doesn't seem to have made much difference, I haven't had a non-starter since then but then I only swapped the parts over last weekend.
The exhaust manifold is blowing a little, possibly affecting the lambda oxygen sensor (screwed into the manifold).
#Cooling#
Whenever the engine is under strain (uphill, or motorway speeds of 75mph+) the needle starts creeping towards warm. This is still happening now, with outside temperatures of 0-10°C.
The thermostat is fine, the radiator looks like new, the coolant is fresh and the summer/winter position of the air valve (determining whether or not air is sucked from the exhaust manifold or not) was fine last time I checked it in the summer.
I'm losing a bit of coolant, but that may also be due to me not doing up the hoses on the radiator properly.
air filter is new, petrol filters may be quite old, haven't got round to replacing them yet.
Perhaps it's a bit early to ask for advice on this, as there are still a few things I'd like to eliminate (fuel filters & exhaust manifold gasket, possible coolant loss), but I'm in contact with a guy in Holland who has following B200F parts.
Air mass meter
ECU
Injectors
throttle housing
Are any of these parts known to cause problems on injected 360s?
The other bits are from a 440/850 ...
Cheers,
Car 1, the '88 GLi
#Starting#
#Cooling#
Car 2, the '88 GLT
#Starting#
#Cooling#
Air mass meter
ECU
Injectors
throttle housing
Cheers,
