300 Parts Clearout !
Posted: 08 Jan 2008 12:33 am
by JOHN360
***AMENDED PARTS LIST***
new unipart 360 clutch £25
new water pump for 240/740 early 360 £20
coolant tank & cap £5
GLT ECU £10
renix unit code 412A £10
airflowmeter 360 £15
virtually new 1.7 alternator (lucas) £20
black vinyl rear headrests £10
wheelbrace £5
instrument cluster with clocks £10
boxed new front door speakers £10
radio reducer plates for din size radios £5 each
GLT air idle valve £5
1.4 bellhousing sensor £5
m3 small silver hubcap £5
Cheers,
John.
Leave a pm, reply or email me at
johnallam@btinternet.com or ring me on 0771 2802774. Located in North Yorks should you wish to pick up.
Cheers,
John.
Posted: 08 Jan 2008 12:35 am
by Ronnie
I'll have the engine mounts please!
Will PM you
Posted: 08 Jan 2008 12:47 am
Sunroof Panel please...
Also what do you mean by:
black vinyl door sticker for 360 models - top part between glass £5
Cheers John, I'dve had the engine mounts too but got beaten
Posted: 08 Jan 2008 01:05 am
by JOHN360
Steve, it's the bit that goes next to the glass on the front & rear door pillars - I can't think how else to describe it really ? I know it was only on the 360's & the redlines.
I'll get back to you both with postage costs, unless Mr F.James is coming up to get the 300 register keeper stuff off me shortly !!!
Cheers,
John.
Posted: 08 Jan 2008 01:09 am
That'll teach me to not check V3M...just posted on the VOC saying I'd have the lot! I'm sure we can work something out guys
Posted: 08 Jan 2008 01:48 am
by Jason B
Will pm, but probably need tie rod ends
Jason
Posted: 08 Jan 2008 09:46 am
by trabitom99
Will PM as well! Am in dire need of a B200 360 water pump (3344252), and would also be interested in:
boxed Volvo cambelt B200 £5
volvo oil filter £5
GLT renix unit £15 (what's the type number on it?)
3rd rear brake light £5
and if SteveP decides not to have the sunroof panel after all (wishful thinking
good sunroof panel I.e. no rust £20
Cheers,
Posted: 08 Jan 2008 10:59 am
by griffo20022
Does the oil pressure gauge come with all the gubbins to fit it? Is it an electrical sender or mechanical? I'd be interested if it were electric
EDIT** Just had a look at the leaflets and I assume it's electrical? If so i'll take that mate! Should fit in a 1.8 16V clio engine still shouldnt it? Would have thought the thread would be the same?
Posted: 08 Jan 2008 11:56 am
If Steve and Tom don't have the black stickers for the B pillars, I'll take them!
Posted: 08 Jan 2008 06:42 pm
by Carl
If there's anyway of getting the red wing down South, then I'd be definitely be interested in it!
Posted: 10 Jan 2008 07:43 pm
by JOHN360
See amended list !
Posted: 11 Jan 2008 03:11 am
Just a thought John...it seems that B19 360s used a standard 2/7/900 series water pump...so you may not have been lied to, as such
Posted: 29 Mar 2008 02:28 am
by JOHN360
Have just put a few items on fleabay including 4 boxed black vinyl transfers that go on GLT /Redline doors I've found !
Also on are the boxed speakers, clutch kit & a 1.7 alternator.
Foggy still has an excellent grey hatch parcel shelf of mine should anyone require one !
Cheers,
john.
Posted: 29 Mar 2008 04:22 am
by simo
Hi John,
I'm in need of a 360 clutch if it fits the '84 GLT? and also the pair of speakers you've just listed. Would you consider ending the auction and send them my way?
Cheers,
Simon
Posted: 29 Mar 2008 08:20 am
by trabitom99
Hi John!
Weren't the bits of vinyl trim part of the parts lot for me which foggy's storing at the moment?
Or maybe you had two sets ...
