today i changed the timing belt of my grandmothers 1982 360 GLT
this is the easiest timing belt i have ever changed ... everything worked fine but now the engine won't start any more ...
i drove to my garage ... so the engine ran bevor i started working ... not very good but it worked ...
1) removed fan
2) removed the two belts for alternator and waterpump
3) removed timing belt cover
4) removed crank pulley by opening the 6 little screws, not the big one in the middle
5) pulled the car forwards that cam-pulley mark matched the mark on the valvecover
6) looked at the mark of the ignition-pulley and saw that it is 1 teeth OFF
7) removed the tenstioner
9) installed the new timing belt with the same crank and cam position, i only moved the ignition pulley to its mark (little dot on pulley -> mark on rear timing belt cover)
10) installed the new tensioner which was the hardest part so far ...
11) then i moved the car back and forth several times to see if everything is correct
12) then i tried to start the engine to see if it is working correctly but ist wasn't starting
after this i thought the timing of the crank pulley may be off
then i moved the engine that the marks on the cam pulley matched and removed the timing belt again
after this i looked for a mark on the crank pulley ...
i found zwo marks on the pulles and one mark, looking like an arrow, on the block
the marks were slightly off ... just 2mm i think ... i checked, if this are the correct marks by removing the sparkplug of the first cylinder and look for the piston ... looked good
i moved the crank pulley that the marks matched perfektly
same with ignition and cam pulley
then i reinstalled the timing belt and tried to start again
same think as bevor ... not even one little spark
are there any sensors that prevent the engine from starting without a working alternator and waterpump?
i didn't unplug anything else ...
hope you can help me
bernhard
