which landrover shocks fit the 340
cheshire190e
Hi, my rear shocks are in need of a change, i see lot of people saying they have used landrover shocks on the rear.
this should stiffen up the suspension a bit but im not sure which ones i need.
anyone know the ones that will fit?
Matt
Matt
1987 Volvo 340 1.7
- jamie_stafford
- Jason B
I keep hearing about this, but do they really fit? - i.e. not just do they fit on the car, but what about piston length with respect to bottoming the suspension out. Also what are the rebound and compression forces of standard defender dampers?
One quick gripe... dampers don't absorb shocks and dampers don't have stiffness
- trabitom99
I did always wonder - what are the advantages of fitted Land Rover shocks? Standard Ebay fare isn't exactly expensive - and if it's race spec stuff you need, keep an eye out for some Konis ...
cheshire190e
Just to be sure before i part with my cash. are these the shocks i need for the rear of my 340?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0086405150
Thanks guys
Thanks guys
1987 Volvo 340 1.7
indeedJason B wrote:One quick gripe... dampers don't absorb shocks and dampers don't have stiffness
dampers control the rebound AFTER the 'shock.' a bit of a misnomer, it has to be said. the REAL 'shock' absorber is your spring.
hard shocks plus weak spring = f*ked shock.
Its been covered by other threads but for the record, you need to double up your leaf springs if you're serious about this or you'll keep breaking your shocks, landrover or not.
mine are getting doubled up sometime before xmas. slightly after ive stuck the webers on
Volvo 360 GLS, 1984, 2ltr 8v SOHC, K+N filter, 2" straight thru pipe, no middle box, lowered 2", Landrover 90 shocks, BBS rims
- filthyjohn
so what do dampers do thenJason B wrote:I keep hearing about this, but do they really fit? - i.e. not just do they fit on the car, but what about piston length with respect to bottoming the suspension out. Also what are the rebound and compression forces of standard defender dampers?
1984 360glt B19 black
Stop the spring from bouncing around like a bouncy thing
yes BUT thats not what they're designed to do..Jason B wrote:Ideally you'd say they provide a force opposing the change in velocity they experience
Shocks DO provide resistance to the spring compression, agreed, hence why most people think they actually make the car stiffer. I think of this as more of a by product though, not the reason to put stronger shocks on:filthyjohn wrote:Erm, and they also control the bound DURING the compression.
The spring takes the energy out of the initial bounce. in coiling up tight under compression, it stores potential engery which shorty afterwards gets translated into expansion (i.e pushing the car back up again). the 'shock' is actually more of a stabiliser; it is designed to limit the number of times the spring will compress and expand from one bump. at the same time, because of the way they are used, they also serve to reduce the rate at which the spring compresses. if you are relying on the shock for this, however, you're using the wrong springs (or ones that are too weak, anyway).
So:
is actually a lot more accurateChris_C wrote:Stop the spring from bouncing around like a bouncy thing
so there
Its a pretty subtle difference.
You can tell when your shocks are knackered by bouncing the car. if it wobbles for ages, they're shagged. If it goes down, then bounces straight back up, with a small hiss, and stays there solid like a rock then they're alllll good.
the real skill (and my 360 is certainly no good example) is in balancing the correct strength of spring (to take the right load weight) with the correct shock absorber. If they work well together, good handling. if not... well, you have to keep replacing them
- Jason B
um..... I'm pretty sure I'm right..... (and chris too - but he mainly does elektrikery so likes to use words like bouncy to describe suspension
springs provide a force proportional to displacement and dampers provide a force proportional to the velocity. The amount of force that they provide (and whether it is in rebound or compression) is trivial and simply a scalar value depending on whatever valving and numbers you want when designing the system.... the principle never changes.
