16v flywheel and tdc sensor
fig roll
Post by fig roll »
do i need to use the 1.7 flywheel and crank sensor to get it sparking? also, which starter?
thanks
Post by 340GLT »
are you going to run it on carbs or injction?
WooDooUK
Post by WooDooUK »
the demsions of the fly wheels are the same inc. trigger patern etc. just the renault 16v flywheel is much lighter.
as for the starter you can use the R19/clio one or the volvo 1.7 or 1.7 clios. I am using one from a later clio they are the same but the later ones have a smaller body.
I believe the crank sensors are also the same.
kaos
Post by kaos »
cant use the renault starter!
thats what adam told me mine didnt work on it.
WooDooUK
Post by WooDooUK »
well becides the fact my starter was knacked it was working fine, no reason why it wouldn't they are even listed in many parts catalogues as using the same starters.
Post by 340GLT »
I think to be honest kaos that starter you were using was tired and on a rebuilt engine just couldnt take tha hack.
Jason B
Post by Jason B »
kaos, I can safely say that the renault one works great after seeing marks car last weekend.
kaos
Post by kaos »
Fair enough..
either way i'll stick to volvo ones for now.
fig roll
Post by fig roll »
340GLT wrote:are you going to run it on carbs or injction?
ill prob be using carbs because a mate has zx9r ones for free, so i guess the best job would be to use the 16v flywheel and starter and just leave the pickup sensor on the bell housing? thanks folks
Post by 340GLT »
You will want the ignition module from the 16v though.
fig roll
Post by fig roll »
340GLT wrote:You will want the ignition module from the 16v though.
why is that? and how would i get vacume advance if i do/
cheers for all the help :D
Post by 340GLT »
With renix units the ignition maps are built into them, they dont need vacuum advance, the 16v doesnt have one.
