B172 clutches NLA
B172 clutches NLA
Post by filthyjohn »
Just been getting some hinge pins and wheel hub bolts from the stealers, and it turns out they don't do clutches for 1.7s any more. Is this recent?
Also, where does this leave you if you want to fit an F series valver?
Post by 340GLT »
Buy a non genuine clutch although beware for anyone buying a clutch from ebay, if it says it fits a 440 series car aswell as the 300 steer clear as the release bearings are totally different so its not possible.
I run a techniclutch clutch in mine although it wasnt cheap, i went for it for the warranty point.
germ
Post by germ »
^^ i thought 440 one's didnt fit as the splines are differnt ( the number of splines)
i got a borg & beck one from german ebay when i did mine, but i believe it was a pre luk one. works well.
nomead
Post by nomead »
I could, at least in theory, get some B172 clutch kits from the local non-genuine parts dealer. Although even then it's not cheap - for the clutch disc + bearing, 99.90 eur for earlier models up to chassis no. 120999 (55 mm bearing); 128.00 eur for later models from chassis no. 121000 on (80 mm bearing).
Heck, I even decided to try ordering a couple CVT clutch discs and bearings through them; if it works, the set will be a bit less than 70 eur in total... and if it doesn't, at least I tried. :)
kaos
Post by kaos »
i can pick them up £50
i have an email on my accoutn from said company i'll try and find them
daffodil
Post by daffodil »
hi i have a brand new volvo 1.7 clutch kit part no 270474, if any body is interested make me an offer it probably the last volvo clutch around
could swap with a 1.4 as i need 1
nomead
Post by nomead »
nomead wrote:Heck, I even decided to try ordering a couple CVT clutch discs and bearings through them; if it works, the set will be a bit less than 70 eur in total... and if it doesn't, at least I tried. :)
Tee hee, indeed, at least I tried. I got the bearings, but not the clutch discs. I even got a reason: the importer was out of stock so it would be a factory order - with a minimum order of 100 discs :shock: ... yes, sure, the price would be right, but what on earth would I do with 100 clutches? :roll: I'm not really used to this kind of obsolescence. From the same aftermarket parts shop I can still get many kinds of parts for e.g. Volvo Amazon and even PV544. Some 300-series parts are still available but there's definitely more stuff in stock for early 240s, for example.
It's mad, you can still buy a complete M47R(!) but not a poxy clutch disc. At least I have a good mate in a motor discount.
