someone broke it!!
time to get all those mods re-installed eh?
Hugh
oops!
oops!
- Duvel78
- Website Admin
Steeeep by steeeep, ouhhh baby!
(talking about the mods that I have to install again, and listening to that 80ies song, only way to keep a smile on my face after that stupid problem with the worm
V3M for life!
V3M for life!
The server got a worm? time for a word with the hosts!!! I take it thats why the front page is... erm..... intresting at the mo!!
- Duvel78
- Website Admin
Yep, a bad worm...
Here is more info about that worm (Symantec website):
Perl.Santy is a worm written in Perl script that attempts to spread to Web servers running versions of the phpBB 2.x bulletin board software prior to 2.0.11., which are vulnerable to the PHPBB Remote URLDecode Input Validation Vulnerability (BID 11672). Other systems are not affected. If successful, the worm copies itself to the server and overwrites files with the following extensions:
.asp
.htm
.jsp
.php
.phtm
.shtm
The worm uses the Google search engine to find potential new infection targets. Google has now implemented blocking Perl.Santy search requests, which is expected to greatly reduce the worm's ability to propagate and lower the risk of further infections.
Also Known As: Santy [F-Secure], Net-Worm.Perl.Santy.a [Kaspersky]
Type: Worm
When Perl.Santy is executed, it does the following:
Searches for "viewtopic.php" using the Google search engine to generate a list of possible infection targets.
Note: Google has now implemented blocking the worm's requests using the search engine.
Attempts to exploit the PHPBB Remote URLDecode Input Validation Vulnerability (BID 11672) to obtain access to the remote Web server.
If successful, it copies itself as the file, m1h020f.
Overwrites files with the following extensions:
.asp
.htm
.jsp
.php
.phtm
.shtm
with the following text:
This site is defaced!!!
NeverEverNoSanity WebWorm generation X
.asp
.htm
.jsp
.php
.phtm
.shtm
Type: Worm
.asp
.htm
.jsp
.php
.phtm
.shtm
V3M for life!
V3M for life!
- Duvel78
- Website Admin
You never saw that text???5lab wrote:i never saw that text
by the way - the smileys arent quite right <-
Try "this site is defaced" in Google and you will see the damage (the past damage cause many websites have solved the problem) > check the cache version and you will see
I know for the smilies, it takes a long time to get everything right! All the mods grrrrr
V3M for life!
V3M for life!
