Tyre Presure
Tyre Presure
I have not checked the tyre presures since getting the 360 GLT of Ben, so what presure would you reccomend with 195/50/15 on it.
- trabitom99
Re: Tyre Presure
Sounds like it didn't have PAS thenvolvosneverdie wrote:I was running 35...
T.
Re: Tyre Presure
It did.trabitom99 wrote:Sounds like it didn't have PAS thenvolvosneverdie wrote:I was running 35...
T.
Whats the correct amount of airs then Tom?
- trabitom99
Re: Tyre Presure
For 195s - no idea! Just looked like you were pumping the fronts up to ease the weight of the steering ...
Re: Tyre Presure
No, I just asked the old man and he said 35front and 32back.trabitom99 wrote:For 195s - no idea! Just looked like you were pumping the fronts up to ease the weight of the steering ...
I blindly accepted.
Any one else got some air ideas?
Re: Tyre Presure
I don't think I was ever that accurate, 30 all round would do
Re: Tyre Presure
That extra 2 on the back adds about 8 HP man!SteveP wrote:I don't think I was ever that accurate, 30 all round would do
Re: Tyre Presure
I think with RWD it's better to have the back pumped up. Whatever your driving wheels are the pressure should be higher to apply the power. Lower pressured fronts reduces under-steer but this doesn't apply to FWD.volvosneverdie wrote:No, I just asked the old man and he said 35front and 32back.trabitom99 wrote:For 195s - no idea! Just looked like you were pumping the fronts up to ease the weight of the steering ...
I blindly accepted.
I think.
- volvodspec
Re: Tyre Presure
with 195/50/15 i do the front at 2.3 bar and the rear at 2.5 bar
that makes 33.4psi front, 36.3psi rear
Re: Tyre Presure
well it sounds very much like i wasnt paying attention and got them the wrong way round.volvodspec wrote:with 195/50/15 i do the front at 2.3 bar and the rear at 2.5 bar
Re: Tyre Presure
Me being a hypermiler i start with the max tyre pressure then -10%
Re: Tyre Presure
Oh and remember if you're going offroad or fancy jumping your volvo, make sure it's up to at least 45
Re: Tyre Presure
Off roads less pressure surely?Speedy88 wrote:Oh and remember if you're going offroad or fancy jumping your volvo, make sure it's up to at least 45
- volvodspec
Re: Tyre Presure
45psi sounds ok for the rear tires if you're planning some drifting..
