Clutch release bearing 1.7
I can source this from Europe for 40Euros but I'd rather not. It's getting so loud now, should have changed it 6k ago :oops: Not desperate but needed quite soon, thanks.
Re: Clutch release bearing 1.7
Speedy88 wrote:I can source this from Europe for 40Euros but I'd rather not. It's getting so loud now, should have changed it 6k ago :oops: Not desperate but needed quite soon, thanks.
Whole 1.7 three piece clutch kit went tor thirty on ebay the other day. :shock:
dez
Post by dez »
yeah, its now bolted to my f7p :D
speedy, you can have my used but nothing wrong with it released bearing for a fiver if you want? i only replaced my clutch as someone hadnt tightened it down properly and it had elongated the holes on the pressure plate. :roll:
"Ive been loved, Ive been hated, to me its all the same. Embraced- Be a lover or your cursing my name"
-1928 ford model A sedan * ratty VW caddy on 13s * volvo s2 343 F7P, 13x8s-
-DD metalworks-
custom automotive fabrication and welding.
Thanks dude but I'm probably just gonna go ahead and get a whole clutch kit, £30 is good and I'm sure I'll need a new clutch at some point
Ok, without going under the car and taking everything apart, I've been offered a supposed '1.7 clutch bearing' from 2 different sources which is a cone shape as opposed to the donut shaped one I was expecting. As far as my knowledge goes (and haynes), the B19 and B200 have the cone shaped one and the B14 and B172 have 1 of 2 donut shaped ones? Am I right?
To explain myself better, I'm actually looking for one of these 2, aren't I? Not the cone shaped one.
Post by 340GLT »
No if you need a clutch release bearing you need the cone shaped one. However there is a small bearing in the end of the crank and also a larger bearing in the back of the bellhousing. When is the bearing making the noise on or off the clutch in neutral?
Ahhh I see. It's when the clutch is on, even when in neutral. But a pushed in clutch pedal stops the sound so clutch release bearing I'm guessing is right?
Post by 340GLT »
Nope more likely bellhousing bearing. As Clutch release bearing is in contact with spinning clutch when you press it. Could also be an unbalanced prop.
Bah fair enough. Cheers adam
