radiator
Joe
radiator
Post by Joe »
Hey, i have a 340 1.4 dl and have got a hole in the radiator and its to big to patch so i have took it out but i was wondering insted off just putting the normal radiator back in is there any other radiators that fit in like the 440 or are all pipes diffrent lengths etc cheers JOE
Roll like its your last time and just let the good times roll
Foook power grow some balls and get commited :)
Re: radiator
Different I'm afraid... I think the 1.4 rad is fairly specific, but are different types dependent on year. Best to try Euro Car Parts for new stock
Re: radiator
A recore is usually the cheapest way, I've had it done it once, seemed to be a good job, lasted well, was about £60 from memory.
Joe
Re: radiator
Post by Joe »
thanks i think i will just get anouther from the scrappy or wait till i get my 440 in
kaos
Re: radiator
Post by kaos »
Most of the 340 ones are interchangable. Ive recently fitted the thicker varient from a D reg in to my F reg 340
Joe
Re: radiator
Post by Joe »
I have just got a Honda civic type r radiator so am going to but that in and put twin fans on it when i get enough money :)
patch79
Re: radiator
Post by patch79 »
alright joe, dont belive the crack, i had a 440 one in my old car, it wasnt a straight swap, i think i had to drill 2 holes in the front panel for the feet to sit in and make some brackets at the top, but all the hoses line up except one which is doubled up on the opposite side but has a blank on it, so just swap it over. basically if you want to make it fit there is normally a way! come to the yard at the weekend sometime earlier than 4.45 and i'll show you the crack. oh yeah, dont leave all the bonnets up this time, LOL they get knackered in the wind and the engines get fecked in the rain, the parts are hard to find :lol: !!
82 golf track car 2L 16v
83 jetta 1.8 16v
Audi 80 estate, 16v quattro Frankenstein creation, with a tow bar!
82 343dl 1.7 turbo, Burnt out shell :(
87 340dl rappidly changing
patch79
Re: radiator
Post by patch79 »
i forgot to say, ive just swapped my diff and gear box, if you want my old one to weld up and play with you can have it, i'll end up taking it to mountelm. your stick welder should do that job fine or ive just bought a better quality mig you could have a go with. i'm off friday and will be at my lock up durring the day so let me know if you want it and you can come and pick it up.
83 jetta 1.8 16v
Joe
Re: radiator
Post by Joe »
ii i will have a play with it give me a bell on friday, if i have my radiator in :S
