I currently have a totally stock 340 which I would like to set up slightly better for a bit of tramp driftage. Nothing serious, mostly in the wet only (Have a 1.4 and sure as heck don't have enough power for dry drifting!) but sometimes find some nice gravel spots too.
As I'm sure you all know, that inside wheel loves to spin.. and does so at every attempt to whack the back out. Can't really afford to have the car off the road for long atm so must postpone a welded diff (although it is on the cards) so I think I need to toughen up the suspension and cut down on the body roll. These things handle like boats!
From the general gist of things, 340s commonly go down by about 2" (50mm) on the front, and 40mm on the rear I've heard?
I am planning to use Defender 90 Front Shocks - http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT(these give 2" drop?) with some kind of lowered springs (don't really want to cut my originals).
Any ideas on what springs I can use? I'm assuming I will need tougher springs with a slightly stronger spring rate?
For the rear I was going to use Defender 90 Rear Shocks - http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT along with some 40mm lowering blocks.. any idea where I can get these with the extended bolts? Are there 50mm blocks available, or is that too low?
Also, would I need to double up the rear leaf springs for this amount of lowerage? If so, can anyone link me up to a decent 'how to' thread or something?
Thanks alot in advance,
Chris
