rear tyers scrubbing on the inside
Hey, my rear tyers are scrubbing on the inside really bad, is it because i have lowered it ? and is there anyway to stop it ? Cheers Joe
Roll like its your last time and just let the good times roll
Foook power grow some balls and get commited
- 340GLT
Re: rear tyers scrubbing on the inside
Front or rear? Wht size wheels/tyres you running?
its the rear and there 155/80/13 just the standerd volvo ones
- 340GLT
How much have you lowered it by? They shouldnt be scrubbing.
- volvodspec
and if it's not been lowered more than 3" you should seriously consider a pair of new shocks if it is scrubbing....
worn bushes could cause this, or a previous shunt which has bent something subtley so you can't tell its happened. If it was a 360 I'd say the car had been ragged and the rear axle has bent, causing excessive toe-in but the 340s don't have the power to do it I don't think.
its lowerd by 3inch there is alot off camber on the wheels, i think it could be the axle not sitting in stright or something its really annoying tho cheerrs joe
- 340GLT
To be fair they should not be scrubbing. Do they scrub whilst driving or just over bumps?
they were scrubbing on the flat but i sorted it with a big hammer
If in doubt give it a clout the bigger the doubt the bigger the clout
- mrsoundcraft
You can come round and sort mine out then.
how exactly did you do that? I had never thought hitting the rear axle with a hammer would straighten it. The springs just seem to take up the shock, and you can't get a good swing with a sledge hammer really.
And believe me 1.4 340s do have the power to bend their rear axle for toe-in, you just need good enough tyres and give her plenty of revs.
I'm thinking a slice through the tube 90% with a big angle grinder, then hammer, but with precision measurement to check the alignment. Followed by welding back up again.
I thought he just meant he hammered the arches out to stop it rubbing?
Yer i just hammerd the arch out a bit and fiddled about with the leaf springs not sure if that did anything tho.
- mrsoundcraft
After measuring yesterday I take back the request for a good hammering. My wheels appear to be parallel, its just the astras impact on the arch that makes it look bad.
