wheel stud specifications
antoni
Post by antoni »
I dont have anyway of measuring the thread etc of the studs on my 340, does anyone know the specs of the top of thier head?
Need to order longer ones for my spacers
also are they press fitted or threaded in
Ant
Re: wheel stud specifications
Post by 340GLT »
They re 12x1.25, if you buy extended subaru impreza ones, drill the hub out to 14mm and refit them. They are pressed in, but you can wind them in with a machined spacer and a nut.
I run impreza ones on mine.
antoni
Post by antoni »
do i have to use subaru ones or can i just hi jack deom tweeks for whatever they have?
2 Fast 4 U
Post by 2 Fast 4 U »
340GLT wrote:They re 12x1.25,
No they are M12 x 1.50
mine are 1.25 like.
:lol:
2 Fast 4 U
I just measured them and they are indeed M12 x 1.25 sorry
antoni
Post by antoni »
so I have bought extended subaru ones, do i just need a 14mm drill bit drill the hubs then bash em in with a hammer and a bit of heat and lock tight?
Post by volvodspec »
yep, apart from beating them in with a hammer...
just use a spacer and a nut to get them in
antoni
Post by antoni »
so i effectively pull them through using the nut against the spacer?
