Electronic power steering progress.
Post by bogbasic »
I have been beavering away at installing the Easysteer rack and tested it today. It seems to be working well, or at least when the rheostat knob is turned towards maximum, the steering is very, very light, even at standstill. I could only run the car for a couple of minutes before it ran out of petrol, so I will try again tomorrow. Interesting times because the Dr advised not to drive at the moment so getting petrol means using a jerry can and going to the garage by train or taxi (the latter would seem best if carrying petrol, officer) - even more interesting because the people I talk to think I am mad to be taking Dr's advice, but then the Dr thinks I am mad, too, so its a vicious circle. Still, perhaps some progress has been made...
... anyhow, I hope to make all the electrical connections proper and start to reassemble everything in the next couple of weeks. Note, I had to use a heat-gun to re-shape some of the ducting, but apart from that the fitting all seems to be great. Maybe it'll be ready for that critical date in early April, MAC take note, but I am serious.
Re: Electronic power steering progress.
Post by Ride_on »
More information! How does connect to the rack, how much etc
Post by bogbasic »
Hello
From memory they quoted about £450 but haven't checked since it was a few months ago. The bottom of the column slots into the universal joint in the footwell. Rick at easysteer did the mods - I would call him. I will post some more photos asap. Cheers, bogs.
Post by bogbasic »
Part way there...
... and here are some views of the underside of the steering column...
... hope this helps. I took the car through a couple of three-point turns in the garage yard and it does work well with the rheostat set about half-way or more.
Post by bogbasic »
It looks promising now. I filed one side of the hole in the plastic mounting bracket for the switches and it is now held on to the column by the screw and some Sugru, for luck. I will try to complete re-assembly in the next day or so and let you know. It all looks pretty promising and makes a huge difference to the feel of the car.
Picture 019.jpg (53.15 KiB) Viewed 51639 times
360beast
Post by 360beast »
Brilliant work, hope all goes well :)
Post by bogbasic »
Thanks for the encouragement!! I just need to re-mould the fibre cover that goes under the dash-board so that it fits around the base of the electric motor. I still need to refit the steering wheel properly and must check if the horn still works because the Easysteer man said that I might need a wireless one!!
Picture 013.jpg (68.75 KiB) Viewed 51623 times
One final technical trick that I forgot to mention is attaching the ECU box to the wiring loom with a couple of Wilko's best self-releasing cable ties (;-0) and note also the intervening bicycle handle-bar grip as a bit of padding to protect the wires which is held on with some tape for good measure.
Another quick check today in the yard showed that it all works well and the Sugru seems to be holding fast.
Post by bogbasic »
Dosing the fibre-panel that goes above the driver's footwell with hot water and re-shaping it over a pudding bowl followed by weighing-it down with a couple of bricks has allowed it to be re-fitted reasonably well. The steering wheel has been aligned and torqued-up. All seems to be awesome and even the horn works.
The rheostat is left showing for now but will be put out of view when I am happy with the setting - currently it seems best to leave it at about the 3/4 mark. Hope some of this helps.
Post by bogbasic »
I forgot to mention its all running from a nice little 40 Amp fuse...
Post by bogbasic »
Converting other 1.7 now. Not so elegant removal of the ignition switch backplate is in progress...
ultrablue 002.jpg (65.1 KiB) Viewed 51528 times
360beast
Post by 360beast »
Good stuff, if you don't mind me asking how much does it cost and is there still a positive feedback from the wheels?
Post by bogbasic »
Well, I am only doing small runs in the yard but the steering feels just like the factory PS on the 360 or lighter. There is no tax or MOT on the car but if you want a crawl round the yard (NB the front of the car in pieces) to test it sometime, just drop me a line. The column was £470.
Post by bogbasic »
Its all a bit more apart now with the ignition switch and column bracket removed.
ultrablue_column_out 029.jpg (86.65 KiB) Viewed 51481 times
For replacing the relays, here are some notes.
ultrablue_column_out 033.jpg (41.35 KiB) Viewed 51481 times
Post by bogbasic »
Hello again, long gap in comms. Here is the latest set of photos showing the new EPS being fitted to the beautiful deep blue 1.7...
... so far so good.
Post by bogbasic »
Hello again folks, a bit more progress on the power steering for the deep blue beastie.
It is all wired in and seems to work well when tested, so it shouldn't be long now.
N.B. I think I had the black and white wires the wrong way round at this point which causes the power steering not to work. I also remember that one of them had to be connected elsewhere in the end to make sure that the PS only came on when the ignition was switched on, otherwise it stays on all the time and presumably drains the battery or knackers itself in no time at all. So whilst the black and white wires look wonderful slotting into that connection block, it is actually incorrect to wire it this way, sorry!!
