ARB Differences?
griffo20022
ARB Differences?
Post by griffo20022 »
Quick question peeps. Are the 360 ARB's thicker than the 340's?
That is all :)
'90 340 1.4 Vince!
'94 BMW 325i Saloon
sven360
Post by sven360 »
No.
You're welcome.
Write it in your heart.
The code of the West.
2 Fast 4 U
Post by 2 Fast 4 U »
:? What is a ARB :?: :?:
kaos
Post by kaos »
Anti roll bar
im gogin to need a new one soon.
Fuse
Post by Fuse »
All models have 19mm I think? I've got some custom made in mine because it's 23mm. :P
griffo20022
Ta' guys, Reason for asking is because i'm buying some Poly droplinks from somebody off a 360 and they asked if I wanted the ARB too. May be able to use it for a rear ARB setup maybe hummmmmm
'90 340 1.4 Vince!
'94 BMW 325i Saloon
Hmm not sure if the drop links will work, the 360 vs 340 have different arb mounts... but not sure if the drop links are the same, can anyone confirm?
Ronnie
Post by Ronnie »
My GLT is 1984 spec (Registered 1985) and it has 340 style droplinks. I think they changed in 1985.
http://www.filterfeeder.eu
Jason B
Post by Jason B »
drop links are different between 360 and 340, though the holes exist on a 360 to use a 340 arb as the actual bars are the same. 360 has a crazy double balljoint thingy that attaches to the strut whereas 340 attaches to the actual suspension arm using a link like the ones dai sells.
...I think
dalahare
Post by dalahare »
86 on 360s have the different setup, my 1985 model uses the same setup as 340s.
Post by classicswede »
griffo20022 wrote:Ta' guys, Reason for asking is because i'm buying some Poly droplinks from somebody off a 360 and they asked if I wanted the ARB too. May be able to use it for a rear ARB setup maybe hummmmmm
If it is off Rich then the ARB is the early type as per 340's
Oh just to add not all 300's use the same thickness ARB some ear;y 340's only had 17mm
griffo20022
It is indeed mate :)
Was gonna say you only make the one time of droplink polys don't you so I knew it'd fit :)
'90 340 1.4 Vince!
'94 BMW 325i Saloon
Post by foggyjames »
You basically couldn't make poly versions of the late-model 360 endlinks (as Ronnie quite rightly says, earlier 360s had 340-style ones).
Technically speaking, the late 360 type is superior....but it's what you can get, I suppose!
Fuse
Post by Fuse »
With some modifications you could actually make poly versions, if you'd convert the setup similiar to one in Group-A 240
http://www.vikeboe.com/Galleri/volvomus ... 61_IMG.jpg
That would require some fabrication though. :P
