That is all
ARB Differences?
- griffo20022
ARB Differences?
Quick question peeps. Are the 360 ARB's thicker than the 340's?
That is all
That is all
'90 340 1.4 Vince!
'94 BMW 325i Saloon
'94 BMW 325i Saloon
- 2 Fast 4 U
All models have 19mm I think? I've got some custom made in mine because it's 23mm.
- griffo20022
- Jason B
drop links are different between 360 and 340, though the holes exist on a 360 to use a 340 arb as the actual bars are the same. 360 has a crazy double balljoint thingy that attaches to the strut whereas 340 attaches to the actual suspension arm using a link like the ones dai sells.
...I think
...I think
If it is off Rich then the ARB is the early type as per 340'sgriffo20022 wrote:Ta' guys, Reason for asking is because i'm buying some Poly droplinks from somebody off a 360 and they asked if I wanted the ARB too. May be able to use it for a rear ARB setup maybe hummmmmm
Oh just to add not all 300's use the same thickness ARB some ear;y 340's only had 17mm
- griffo20022
It is indeed mateclassicswede wrote:If it is off Rich then the ARB is the early type as per 340'sgriffo20022 wrote:Ta' guys, Reason for asking is because i'm buying some Poly droplinks from somebody off a 360 and they asked if I wanted the ARB too. May be able to use it for a rear ARB setup maybe hummmmmm
Was gonna say you only make the one time of droplink polys don't you so I knew it'd fit
'90 340 1.4 Vince!
'94 BMW 325i Saloon
'94 BMW 325i Saloon
- foggyjames
You basically couldn't make poly versions of the late-model 360 endlinks (as Ronnie quite rightly says, earlier 360s had 340-style ones).
Technically speaking, the late 360 type is superior....but it's what you can get, I suppose!
With some modifications you could actually make poly versions, if you'd convert the setup similiar to one in Group-A 240
http://www.vikeboe.com/Galleri/volvomus ... 61_IMG.jpg
That would require some fabrication though.
