Brake upgrade Project (Disks all round) Completed!!
Awesome work mate - I'm sure it'll stop as good as it all looks!
Post by 340GLT »
Right update time, the brakes are nearly bedded in now and i am getting a good feel of the pedal now.
When i first set it all up and took it out the brakes were spongy but it would still lock up a front wheel at low speed!!
In total the brakes have been bled 5 times!!
At speed the brakes dont need to be used past half pedal otherwise the braking is to heavy, it slows down very rapidly and at low speeds like 5mph, on tarmac it WILL lock both fronts if you jab the pedal!!
They will need minor adjustment and i want the handbrake to lock up, but i will need more of the pad surface worn on the back before i can adjust them up.
I feel its a very acomplished setup and am very pleased with the results!! I definatley recommend something for those of you going to stupid power!!
As for the suspension thats pretty gud too now, i chucked it round a tight bend on the way back from work and she was nearly totally level, just turned straight in!!
340cbr
Post by 340cbr »
Do you have some brake distances to compare?
But the best in your brakes is that they will not become hot as quickly as the standard ones...
| 92' 965 Turbo 16v | B204FT - 190hp |
Had: 90' 340 GL + Turbo | B18 FT | Koni's | Alpina White |
SoLaMaNdA
Post by SoLaMaNdA »
Wow, very very very trick. That is something I'd love to do to my car! Can I have a go and see if I can get them to fade? :lol:
Gulbrandsen_Racing
Post by Gulbrandsen_Racing »
hmm, i love this.. you wouldnt make me some brackets, so i just can bolt it on to my car? sm60
I'm wondering on 5-link too.. Get it approved, and legal on the road..
Post by 340GLT »
Gulbrandsen_Racing wrote:hmm, i love this.. you wouldnt make me some brackets, so i just can bolt it on to my car? sm60
I'm afraid its not as easy as that!!!
Gulbrandsen_Racing
make it easy! There's nothing that money can't buy.. :P
Post by 340GLT »
What i mean is even if i did just make you the brackets thats not all you would need, the hubs have to be machined and thread inserts put into the strut!!!
Gulbrandsen_Racing
Oh, i see.. Well well, i'll just have to buy third-party brake discs then.. :P
alistairolsen
Post by alistairolsen »
need gen
adaptor plates look simple enough if youd be prepared to shre the dimensions. Whats the story with the spacers between the adaptor plates and the caliper? Just smooth bore thickwall tube effectively? The inserts you refer to, are these in the original mounting bosses?
Many thanks.
