1.4 > 1.7 radiator?
chunk
1.4 > 1.7 radiator?
Post by chunk »
Quick Q, will a 1700cc rad fit my 1400cc???
Thanks guys
Rich
IvanAE86
Post by IvanAE86 »
Probably... cant remember anything sticking out there that might interfere.
ducatievo
Post by ducatievo »
Can't recall if you might need to do a little chopping for the pipes, I had this when I stuck a new rad in my old 360. Nothing major though.
chunk
Post by chunk »
Thanks guys, my 1400 is getting a tad warm, so im hoping the thicker 1700 rad will sort that, we can only see though :)
ATB
Rich
It depends what type of 1.4 you've got. The later 1.4s have an identical radiator but the early ones have a smaller one inside the engine bay.
IvanAE86
Post by IvanAE86 »
Make sure you get the radiator shroud that goes with it while your at it.. (I always get my volvo 300 parts at the wrecking yard), you might need it to fit the bigger radiator.
tigersport
Post by tigersport »
I know you've probably done this fitment already, but when I changed my radiator in my old 1989 340 1.4, the only thing I found to be different was the little rubber feet that held the radiator in. Those used to be cheap at the dealer too... because the ones in the car I took my replacement radiator from fell apart.
Also I remember that when it was with the thinner radiator it did get really hot, but the fan kicked in before it got to the red. When the bigger radiator was in it got to the hot end less, but it still got up there a bit in traffic.
Ronnie
Post by Ronnie »
Slight threadjack... What about a swirlpot? Anyone tried one of these? Any opinions?
I am needing to get a new rad for the '60 and was planning on fitting a swirl pot too while I'm at it - unless the concensus is that they're a waste of time
http://www.filterfeeder.eu
IvanAE86
Post by IvanAE86 »
What's a swirl pot? And why bother if it doesnt run hot.. If it's not broken, dont try to fix it!
The 360 radiator keep the 2l engine cool with ease, the only situation that might require more cooling is a driftcar. Constantly going sideways with little air hitting the radiator straight on while revving it to the limiter tends to overheat cars sometimes.
Ronnie
Post by Ronnie »
Sorry, been away for a while due to some kind of V3M freakout which kept on telling me I was "Forbidden". seems to be working again now! :D
A swirl pot sits inline with the radiator intake and spins the coolant so that all air is removed. Less air means better cooling and fewer hot spots in the system. I've had 360's overheat, two different cars, both on hot days on very hard runs. Anything that makes the system more efficent will put less strain on components and lead to longer life. A good enough reason to fit one in my book.
Also, the drifters need all the cooling help they can get with their low speed, high revs application. (Not that I'm a drifter)
I towed a caravan using full throttle at 3,500 RPMS struggling up a hill for over 30 seconds and not even a sign of the temperature going up. It was last weekend though, when the weather was cold. Other things like exhaust mounting rubbers started to smell a bit though ;)
I would suspect your radiators were starting to get less efficient, either through partial blockage or coating of the insides with scale. In the height of summer, my 360 refused to even warm up properly until I changed the faulty thermostat.
jimf671
Post by jimf671 »
1.7 radiators are sh1t.
I fitted a 360 rad in my old 340. Had to do a fair amount of soldering and entertaining copper-craft but at least it didnt corrode away by the end of the year!
no, your 1.7 radiator was sh*t. When we changed ours for a proper new one, the car would struggle to warm enough to run without choke, even in the height of summer.
Made me regret not spending the extra ten quid on a new thermostat.
