I have recently had a problem where when on motorways in 5th doing steady 3-3500 revs after a while the car just kangaroos then cuts out. I thought this could be the fuel pump. but...
I recently purchased an electrical fuel pump and a new cam from Dai, I have fitted both of these and now i have an even worse problem, and i have to drive back to uni at the end of the week
Basically the car idles ok when in neutral and i can press the accelerator pedal and hold the revs at any speed, but when i try and drive my car its ok for about 10 seconds and then just looses all power, kangaroos and cuts out, this happens in all gears and i cant drive for more than a few miles before having to wait 20 minutes then it will start again and i can get about another 2 miles.
Im loosing patience quickly and dont know what to try.
Please help me
thanks alot
Matt
Just another thought, my dad seems to think it could the renix unit does anyone else share this thought
Have you drilled the jets yet? That'd be my first idea, it sounds like the top end is all out. Put back the orig cam, and orig jets if you can, get it sorted before playing about tuning it!
Tried to suss out the problem before, this is what i have so far.
The carb is getting fuel
The car runs fine for a while then cuts out after about 10 minutes, it fails to start straight after but then after about 5 minutes it will start up again.
The alternator is dead
I am starting to think it could just be the battery is dead, so it will work fine for a few minutes then after driving for a while there is not enough power to make the spark so it starts cutting out.
then after waiting the battery has long enough to recover to start again.
I think this because the problem is getting worse and worse and the time between being able to start the car is getting longer and longer.
I have put my battery on charge, so ill see if it drives fine for an hour or so in the morning. If not im stumped
it sounds like its running on 3 cyl or less. did you blow the fuel lines out?
another thing is the dizzy cap can fill with oil and stop it working properly. have you checked the plugs? if one is cracked or something or even the leads, they could be damaged(even if they are new!)
I think i have finally sussed out the problem. hopefully
Basically, when the ignition is turned on the fuel pump is working as normal and is pumping fuel at a steady rate. But when the car is running the pressure drops dramatically and barely any fuel pumps through.
I have tried hooking the fuel pump up directly to the battery but it still looses power when the car is running.
Is this due to a bad earth somewhere? how would i go about fixing this?
I have just fitted a new alternator and the problem is still there, I have earthed it to the lower right hand side of the battery tray where the engine earth goes.
Is there another place to earth it which may be better?
