finally driving my 340, couple q's
right, my old car sold on sunday, and finally driving my 340. lol
just a couple q's
how do people find the road noise? i can open and close the window, and if i'm not looking i really cant tell if its closed as there is that much road noise. sounds like a door is open when it isnt. lol.
how much fuel should it be using? i put £10 in on sunday, and just about managed 60 miles,
just a couple q's
Re: finally driving my 340, couple q's
is it a sunroof model?
try opening the roof half a crank to seal the gap. (check by eye from exterior).
at set fully closed, theres normally a ma-hoosive gap that blows hard above 50mph man.
Also check for split or detiorated door rubbers.
Fuel eccon?
Carb?
theyre not frugal even when running great.
1.4?
or 1.7 man?
Fuel eccon?
Carb?
1.4?
or 1.7 man?
Aye lad, be careful of split rubbers.
lol
na its not a sunroof, just sounds like driving along with the doors on the catch, lol. and no sunroof
and its a 1.7 carb
and its a 1.7 carb
If it's a 3 door, check if the rear side window seals are perished... my 5 door 340 is much quieter than my 3 door 360 for this reason. The door seals were already mentioned, if they're non-elastic and let air between it and the door frame, you'll get wind noise.
Volvo 340DL Variomatic -89
Volvo 360GLT -86
Volvo 360GLT -86
yeah i had a look at my door seals yesterday. absolutely rock solid and not even touching the doors, lol. no wonder there is wind noise
do volvo still do them?
also, my window motors are packing up on both sides. lol. big job? as window mechs are a pet hate of mine.
monka wrote:yeah i had a look at my door seals yesterday. absolutely rock solid and not even touching the doors, lol. no wonder there is wind noise
Woo-hoo!
I got something right.
A scrapper is your best bet.
There a few breaking on here atm. Best put a thread up in WANTED man.
If you COULD get them from volvo, theyd cost about one billion dollars.
Yeah I was about to say door seals... not sure if volvo still do them but easily available from classic car trim manufacturers I would've thought.
Motors... are they just slow? If so take out the motors, run loads of wd40 through them and clean up the mechanisms and theyll be fine
The door seals should be easy, the profile is very close to generally available "classic" seals with no vulcanized corner bits etc. Also the hatch/boot seal seems to be easy to find. (If the door seals are gone, the hatch seal will likely be dead too and leaking water into the boot...) I'm still looking (or a local supplier, Oitracon, is) for the rear side window seals though. That seems a bit more special...
Volvo 360GLT -86
Volvo 360GLT -86
yeah motors are slow, althoughthe passenger side randomly decides whether or not it wants to work when i press the switch. lol
Yes the switches can go aswell with the current, some 740/940 ones work. I'm sure people here have 300 series spares.monka wrote:yeah motors are slow, althoughthe passenger side randomly decides whether or not it wants to work when i press the switch. lol
if the motors are just slow the gearbox can be a bit siezed and WD40 will fix if you work it loose with mole grips on the outer gear. Should be ok provided the gearbox has no angular play/rock. Also clean up the motor brushes and rub down armature contacts with wet+dry 400-800 paper until bright and shiny.
Wind noise should not be bad but it depends what you are used to, if a door sounds open there probably is a gap. A modern car like a 97 3 series BMW will be much better with rubbers on the outside gaps aswell as the inside ones, more sound insulation etc. Consider holes or plugs missing from the inside steps beside the seat base, these are for access for internal rust-proofing and are often neglected during various work.
MPGwise if you paid £1.07 for your petrol you would have 29.3mpg which isn't a bad average or a 1.7. You might get 35MPG on a 25mile motorway journey taken at 60mph.
There are a lot of companies that if you fax or email a piccy of the cross section with dimensions, they'll send you the closest one. Worth an ask.monka wrote:http://cgi.ebay.co.uk/UNIVERSAL-RUBBER- ... 2303669a38
just found this on ebay, any good? thoughts
if some one could get me a pic as i would need one, as my seals are quite literally flat, lol.
