Polo G40 vs Volvo 360 front shocks
meintag
Post by meintag »
Thanks again !!
Maybe will be not the optimal in a B200 but they worth a try... :wink:
Frits
Post by Frits »
I believe the smedberg 360 rallycar has the same.. Probably good enough for your 360 too :]
If not, you can always donate them to my B14HPT 343 :] hehe just kidding
Fuse
Post by Fuse »
R-Sport shocks are very rare.. DeCarbon is the manufacturer and front shocks are monotube design. Bilstein "copied" the monotube design from DeCarbon. :P ("Copied" as they paid patent fees for them back then)
Ozbrick
Post by Ozbrick »
The Tie rod ends from the 78-82 Golf are identical to the volvo 360 GLT ones, there seems to be some part sharing here!
1985 - Volvo 360 GLT - V3M downunder! Uprated coils and leafs, Gas shocks, 3A Racing Filter + balls!
2002 - Renault Clio Sport - http://www.ozrenaultsport.com/forum/vie ... php?t=7697
The top of the casing is likely to be an issue, I think. IIRC, Adam had to have larger diameter strut tubes welded to the stubs of the originals in order to use more common 45mm inserts. 42mm appears to be an oddity.
