Hi guys, new to Volvo so this'll prob sound daft but I've got sender unit troubles I think, my fuel gauge reads zero even when the tanks full.
The daft question is where is it and is it easily accessible?
Anyone had this trouble before and have a remedy for me?
Si
P.s the cars an f Reg 340!
Dodgy sender unit?
Dodgy sender unit?
1988 Volvo 340gl 1.7t.........gone but not forgotten!
1997 BMW E36 coupe 323i....2500cc's of straight 6 RWD driftiness!
http://www.facebook.com/profile.php?id=1370011019
- Hell Driver
Re: Dodgy sender unit?
Hi, welcome to the forum, sender unit is accessed through a hole in the boot floor, under the carpet. Unscrew the 3 tiny screws in the round black metal cover and remove it and you will see the sender. Check the connections are on. From memory, it the sender is faulty then it's easy to take out, but you will need to get the petrol pipes off to remove it. Mark them cos one is petrol out and the other is back in from the engine, don't let them go back under the boot floor where you can't reach them again! If I remember rightly, the sender screws out.
343 DL (W 80)
R.I.P. 77 343 DL vario
343 DL (W 80)
Cheers,
I'll check it out at the weekend. Apparently it was working before I picked it up so I'm hoping it is just something simple
- volvodspec
it's probably a souvenir from your engine conversion, as yours has been converted from mechanical to electric fuel pump (for the turbo engine) they had to alter the sender unit for bigger pipes etc. and a internal or external fuel pump; i bet something went wrong or has been forgotten there.
Apparantly it was working until the day before I picked it up, he filled the tank and it stopped working?. I'm hoping it's something simple like a wire that's just worked it's way loose while the cars been thrown aboutvolvodspec wrote:it's probably a souvenir from your engine conversion, as yours has been converted from mechanical to electric fuel pump (for the turbo engine) they had to alter the sender unit for bigger pipes etc. and a internal or external fuel pump; i bet something went wrong or has been forgotten there.
If he's telling the truth it might be the float arm that's disconnected.
Ive no reason to doubt him, he's a good mate and wouldnt fob me off. Is the float arm an easy fix?Speedy88 wrote:If he's telling the truth it might be the float arm that's disconnected.
Si
It's mechanical. So yes. Take it out and have a look, no point speculating at this point.
Cheers,Speedy88 wrote:It's mechanical. So yes. Take it out and have a look, no point speculating at this point.
I'll have a look at the weekend if time allows.
Well that was an easy enough fix!
Unscrewed the cap in the boot and was greeted by the wiring clip unplugged
plugged back in and alls good
Cheers for the tips.
Si
Si
