Ali's drift 360 project
Ali
Post by Ali »
Well its just turned up :D
Post by jtbo »
Looks nice, there is also little notes what wire is which, much better than my guessing from blue or red wire :lol: Well I had actually also purple and black wires too :P
Nothing will ever beat that Jani... you must be the only person who can make wires less neat than Andy :P
Post by jtbo »
Chris_C wrote:Image
Could be, mine still works :lol:
Telling the truth, I'm completely missing that part of brain that tells how to make wires or anything else neat :oops:
Ali
Post by Ali »
Right well MS is about half fitted, *should* be all fitted, running and road legal by next week which I cannot bloody wait for! That involves passing an MOT on sat though, there's nothing obvious it should fail on but theres a few things I haven't tried putting through a MOT before (bonnet pins - duno what they'll think about sharp edges, just small stuff like that). Got an inlet temp sensor today and mounted it up into one of the pipes in my intake system...
Post by foggyjames »
Nice :-D Keep us posted!
Nick C
Post by Nick C »
bonnet pins shouldn't be a problem, I know of several cars that get through MOTs regularly with them.
Ali
Post by Ali »
Ah ok thats good, i'm going to take gaffer tape incase I need to cover them up mid-test haha, going to try and stand over the guy incase I can fix anything on the spot lol, just hope he isn't picky, i've put the seatbelts back in but the cage is getting in the way stopping the drivers side from coiling back in properly, leaving the harnesses there and going to point out I never use the seatbelts anyway, theyre just there for the BS mark lol
germ
Post by germ »
hehehe lol^^
its not an sva test you dont have to worrie so much about sharp objects and such just make sure all your doors open form the outside lol :lol:
will
Volvo 340 Image 1988
germ wrote:its not an sva test you dont have to worrie so much about sharp objects and such just make sure all your doors open form the outside lol :lol:
IIRC I think you do... rust will fail on the MOT if it produces sharp edges that could come into contact with the person. No idea on bonnet pins, but tape em up so they're smooth and it should be ok...
Agreed, they do check sharp edges, they have a special ball on a stick incase they are dubious. Would the seat belts be like a spare tyre? i.e. if fitted they have to work, if not in the car they don't care?
Nick C
Post by Nick C »
you have to have e-marked seat belts fitted, but they don't have to be the originals, so if you have suitable harnesses, the inertia belts don't have to be in place. stage rally cars generally only have aircraft-buckle harnesses and get away with it, although I have heard that you have to be able to to the belts up with one hand, which you can't with aircraft-buckle harnesses, but can with seatbelt-buckle ones. I'd have thought just harnesses would be better than having non-functioning inertia belts....
germ
Post by germ »
they really use the stick thing in mots never seen that before only in sva test but maybe its differnt all over the country.
seat belts are compulsary in the front and i think in the back too since 80's but if you dont have seats in the back should be ok
best is to see what happens but do any thing you thinks obvius first.
will
MJ
Post by MJ »
Surly there must be an official MOT check-list somewhere that has a list of all the tests so that you can prepare?
Post by redline »
just take it in and see what it fails on ,
If you can repair it at the testing station or they do the work for you then they should retest it for free.
or you can take it home and repair it you have ten working days to take it back for a retest, as its only a partial test only a partial retest fee should be charged but most garages I know don't charge for the retest .
sharp objects can cause a car to fail if its considered they could be hazardous to pedestrians
I guess this would fail the mot then
what part of the bonnet pin is sharp ? all the ones I have seen conform to road safety standards
