Ali's drift 360 project
Post by foggyjames »
Ooh, there's the money shot :D
Grand, I wasn't going to touch it until I saw smoke tbh, just was intrigued incase that ment I had about 5 more mins of running time :D
Stavros, how do those bearings work, are they ball raced in any fashion, or it is just a metal on metal friction surface? I figured that at the speeds we are looking at, it'd be something more complicated than that!
I believe the oil is under sufficient pressure to create a 'cushion', as with the engine internals, but I'm not sure.
Stavros
Post by Stavros »
Yup, just like engine bearings, it sits on a film of oil, in the turbo its under pressure so the shaft literally floats in the middle.
Ball bearing versions obv fit on ball bearings, and there various versions of them, some of the latest ones almost need no lubrication, but less oil means you need a lot more water cooling to stop them overheating, so they have massive water passages compared to non-BB turbos which can all happily run with no water cooling, even if they came with em as standard.
Ahh, ok, that makes sense! Cheers guys!
Ali
Post by Ali »
3 hours at the scrappy and £30 later......
There were two at the scrappy, sods law the one with easy access had just as much play as my current one! This one has a tiny bit side to side but nothing in and out so bloody hope its ok. Got this far but then starting to run out of light and can't face getting snowed on for the 2nd time today :evil:
I've left the sump with "MetalFab" and picking it up tomorrow afternoon :)
Jesus, quick work mate - soon be back together :)
Ali
Post by Ali »
I'll get slapping it back together :D
That's the chap! I can see that getting cut down a little though sm56
Ali
Post by Ali »
Already cut down and on the car :D Its running fine again, no smoke yet but its still up on ramps so haven't got it on boost yet. Its also running really lean, not sure if the new turbo is spinning more freely and therefore supplying more air or something but i'll have a play at the weekend and hopefully get it through an MOT
Ronnie
Post by Ronnie »
Chris_C wrote:I've been meaning to ask which way is bad for spindle movement, I have a erm, friend, with a turbo, that has a lot of in/out, but no side to side movement, and it doesn't blow smoke. See how it goes I guess, I was wondering if it could be recon'd.
Good doc Here, Chris
http://www.filterfeeder.eu
Did Andy set up your warm-up cycle? If not, that may explain it...assuming it wasn't that warm!
Cheers Aaron, I hadn't found that!
Ali
Post by Ali »
Right guys i'll update later on today but MY F**KING GOD! ITS FAST! THeres still some little niggles and the turbos smoking on full boost quite a bit so not sure if thats still drain problems or another less knackered turbo haha, we stuck it on powerdyn and its about 175bhp and 180lb/ft and feels like it too! I'll update later with a video and some graphs, oh forgot to say, its passed the MOT!
Post by jtbo »
Ali wrote:Right guys i'll update later on today but MY F**KING GOD! ITS FAST! THeres still some little niggles and the turbos smoking on full boost quite a bit so not sure if thats still drain problems or another less knackered turbo haha, we stuck it on powerdyn and its about 175bhp and 180lb/ft and feels like it too! I'll update later with a video and some graphs, oh forgot to say, its passed the MOT!
:D :D
If smoke is black that is just bit rich which is just good, if white/blue then something else like turbo etc.
So is there now trouble with grip? But of course when drifting that is not a problem :P :D
Do you have pic of powerdyn curve? Would be interesting to see what kind of output is :)
