Ali's drift 360 project
PWN3D!
SJS has knock sensing in his B254, I think.
Send PM as I think he is not reqularily scanning this board.
Uups, made spelling error last night, fixed now :P
Lol, well in my defence the parts we are using are such uncommon pin layouts, they don't actually exist in the software ;)
Believe me, I didn't go adding components to the thing cos it seemed a fun way to spend a Saturday afternoon :lol: :lol:
Ali
Post by Ali »
New stuff arrived today.....
MSnS should arrive tomorrow, just need to get hold of the TPS and temp sensor now, then the wiring fun begins :D
Where did you get yours from Ali? I'm thinking of holding off on the wideband and MS for a few months, but you know when I get it running that'll change :twisted:
Ali
Post by Ali »
Got it from Bill Shurvinton, £135 delivered, just got back from the scrappy, got the coil and lead so just need TPS and temp sensor now
Ali wrote:Got it from Bill Shurvinton, £135 delivered, just got back from the scrappy, got the coil and lead so just need TPS and temp sensor now
You mean you forgot the temp sensor at the scrappy ;) Coming along nicely, though
Innovate LC-1? Shoulda told me, a mate is a dealer...;)
Ali
Post by Ali »
Right little update, still waiting for the MSnS to arrive, swapped the turbo injectors onto the car and plumbed up the intercooler to the inlet manifold, might require a little modification for the inlet temp sensor but haven't bought one yet. Tonight I made up the adapter plate for the TPS...
Nice work Ali! It looks a little more professional than Andy's superior quality bodge sm56 sm56 sm65
Ali
Post by Ali »
Haha cheers, tbh I would have used wood but couldn't find any the right thickness! If i'm feeling energetic I might cut it down a bit and round the corners as its a little on the large side for an adapter plate lol
foggyjames wrote:Nice work Ali! It looks a little more professional than Andy's superior quality bodge sm56 sm56 sm65
At least I didn't have to 'adjust' my bodging three times before it would work properly. Do your carbs still smell of fuel? :P
It's not just the carbs that smell of fuel... :lol:
Well, they wouldn't smell of fuel if theres no fuel getting to them :wink:
I did made adapter plate from original metal adapter plate that sits under that original throttle switch, just did cut d-shaped shaft and drilled few new holes to adapter plate, very stock like look with that.
If I had installed FP under the car and done wiring properly using original harness there would not been anything to criticize with my install, however my stylish FP install to manifold and open wiring was not too pretty I must say :lol:
Here you can see TPS and that rather stylish or perhaps artistic wiring ;)
Click image to see it bigger.
Then I had chav filter at beginning, it flew of once when I floored it and for some reason Renix did decide that it is ok to fire spark now, huge BANG and filter was gone to some better place. That small hesitation was always because of renix, had not that with MS controlled spark and not other problems either.
Ali, study those photos and make notes how not to do things :D
James, you sure that it is good put that carb fire out with fuel? :lol:
