Hi there, hope someone can help me. I'm from South Africa & just purchased a 1986 Volvo 360 GLT & as they weren't shipped to South Africa, I'm battling to find some parts. Is there anyone out there that can help me with the following parts:
tail lamp right hand side, direction indicator right hand side, door handle right hand side, a Renix S100941-408A control unit, impulse sensor & finally ignition coil. Many thanks. Markus
360GLT parts required
swedespeed
Re: 360GLT parts required
Hi mate and welcome.
I can do the Tail lamp,indicator stock and door handle.
The renix is pretty reliable are you sure you need a replacement, the coil is replaceable from any unit/car post 83 as is the crank sensor. Crank sensor failure is common. If you have a non-starter try posting the problem. Most common problem is the injector pump fuse contacts behind the battery.
Some engine type bits you might be able to get from a Renault main stealer.
